Hi
I am new to the forum and have always looked at the site for valuable information. I have the dreaded problem of the red light on the dash where my roof will not go down on my 2009 E89 Z4. I have had a fault code come up stating fault code A69C. This states valve 3 for retractable hard top. I have checked all the sensors on diagnostic tool and all appear as they should, I have replaced both salmon relays as they look original, have had the motor off the pump unit and put a temporary power supply to it off the battery and it wizzed around. So I am hoping it is the solenoid to valve 3 which I have ordered. I am awaiting for it to arrive but was wondering if anybody knows which it is as they do not appear identified in any way. I assume it is one on either end. I have a 3 valve version for the 2009 E89.
Any help would be much appreciated. Thanks in advance.
Valve 3 on roof pump
- RobbiZ4
On the E89 hydraulic pump, the valves count from rear to front.
However, this varies from model to model and from car manufacturer to manufacturer!
Tip:
As these valves / solenoids hardly ever fail, you can take these parts from used hydraulic pumps offered on i.e. eBay without any risk.
Tip:
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Thanks for the prompt reply. I have bought secondhand tested and 12m guaranteed part so keeping fingers crossed. They seem easy enough to change over but didn’t want to play around with them more than I have to. On that basis it appears I should try the solenoid closest to the seats first. Many thanks and I will let you know how I get on.
- RobbiZ4
This is the first damaged solenoid I've seen some weeks ago. It "died" due to overheating in the coil, where it burned a small hole into it's housing.
Inbetween BMW charges about 250€ for this simple solenoid. Unbeleivable!
https://www.leebmann24.de/magnetventil- ... 53599.html
Wow, I will take a close look at mine when it is removed. Thanks for the great information provided.
Hi, update on the replacement solenoid. I replaced the valve 3 solenoid and when I pressed the button for the roof to go down the same message came up. I have attached image of message below. Checked all micro switches and appear in the correct format for a roof in the correct position of roof being up. I am starting to wonder if it could be a wiring issue. Don’t know if anybody had any thoughts? Is there an easy way to carry out a test I assume on the yellow and brown wire which goes to the solenoid?
Any help would be appreciated.
- Micro switches 2 of 2
- 65DF9410-0229-464B-A759-3293732AC749.jpeg (147.19 KiB) Viewed 470 times
- Micro switches 1 of 2
- E2E3A8F9-172A-44E7-8D8B-EB30465261DE.jpeg (149.4 KiB) Viewed 470 times
- Valve 3 fault code
- E021D301-BC20-400F-B314-9D2D08C0456D.jpeg (115.66 KiB) Viewed 470 times
- RobbiZ4
OMG.
Well,
Check the wiring between the green plug on the CTM and the 3 plugs on each solenoid. Is there a short, a broken wire or a contact against mass?
You can test each solenoid with a 9V block battery: does it click?
This fault is absolutely unusual and I've seen a defective solenoid only once.
Well,
Would have thought only way it knows it's faulty, either wrong resistance as it checks current or open circuit, thus broken coil or wire.
I would trace wires back to control unit and check.
