Hi all
Have just bought Z4 3.0 SE 2006 , it came with 225-45-17 wheels and tyres but have replaced them with my old 135i coupe wheels 255-35-18 rear and 225-40-18 front.
Any suggestions for best size wheel spacers front and rear and suggestions for what size lowering springs.
Many thanks
Keith.
Wheel spacers and lowering springs
- Panta Rhei
E87 OE 18" wheels are:
7,5x18 ET 49
8,5x18 ET 52
E85 OE 18" wheels:
8x18 ET 47
8.5x18 ET 50
You are 8,3 mm inside on fronts and 2 mm on rears compared to OE.
Keeping in mind that without lowering you can go +10 to +12 mm front per side and even +25 mm rear per side on OE E85 wheels and on lowered (eibach -30 mm - compared to OE standard suspension) however 5 mm front is max because of front inner wheel arch and this arse side marker design.
Quick maffs...
Use 15 mm front and 25 mm rear per side
This will push wheels out 23 mm rear and 6,7 mm front compared to OE on 5 mm fronts and 25 mm rears - all safe and tested.
15 mm spacers require longer wheel bolts. 20+ have through opening and current bolts can stay.
7,5x18 ET 49
8,5x18 ET 52
E85 OE 18" wheels:
8x18 ET 47
8.5x18 ET 50
Quick maffs...
Really appreciate your response mate.
Thank you very much for your advice
Keith
Keith
