Broken wires in the roof shell are difficult to identify visually without dismanteling the roof shell.
Yep, another roof issue.. can someone help me?
- RobbiZ4
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Ah ok. I was thinking of taking a look at the ones at the edge of the roof as seen here at the 10min mark: https://youtu.be/3q52HtkK6mU ...I know that's a very specific scenario but I think I'll take a look anyway, just to eliminate it if anything.
Just to confirm, there are two hall sensors on the right ram, correct? Can they be cleaned at all?
I really do appreciate your advice. Thank you.
- RobbiZ4
Yes, there are 2 on the right, none on the left.
What dou you mean with "clean"?
They have to get removed for checking, replaced with new ones if rusty, nothing else.
Here is a link to pics:
viewtopic.php?p=1921079#p1921079
Yes, just meant if rusty. Thanks, I'll take a look at the link my friend.RobbiZ4 wrote: βSat Jun 18, 2022 12:20 pmYes, there are 2 on the right, none on the left.
- RobbiZ4
Well, in this special case it means, that it's electromagnetical functionality is destroyed and it doesn't work anymore as intended. This can't be cleaned and has to be replaced.warmasice wrote: βSat Jun 18, 2022 12:24 pmYes, just meant if rusty. Thanks, I'll take a look at the link my friend.RobbiZ4 wrote: βSat Jun 18, 2022 12:20 pmYes, there are 2 on the right, none on the left.
- Ole gits rule
I am certainly no expert but the failure seen is very similar to what I had and Robbie diagnosed this, went to a local and indy and they confirmed microswitches.
M4 Vert in Yas Marina Blue
- Deepseaskateboard
This is from my invoice.RobbiZ4 wrote: βSat Jun 18, 2022 10:16 amWhat is that?Deepseaskateboard wrote: βWed Jun 15, 2022 11:15 pm There is an updated wiring loom which can be fitted.
I love these web recommendations about things, that one have never dealt with before.
I think the part B61 is the new wiring.
- CE897824-D082-4868-9289-008DACA3707F.jpeg (82.78 KiB) Viewed 363 times
- RobbiZ4
No, part B61 is a short cable adapter for this microswitch coupling fastener to support an improved plug(!) format.
That has nothing to do with the critical and expensive hydraulic harness in the roof, we are always talking about (and where the sensor wires will break). It cost's more than 1.000 Euros (54377311084).
https://www.realoem.com/bmw/de/showpart ... 1132359999
- Deepseaskateboard
I was meaning wiring, not hydraulics!RobbiZ4 wrote: βMon Jun 20, 2022 1:46 pm No, part B61 is a short cable adapter for this microswitch coupling fastener to support an improved plug(!) format.
Itβs expensive if they go awry.
So this is an adapter which allows the old wiring to be connected to a new version microswitch?
- Smartbear
Yes, the plugs are different.Deepseaskateboard wrote: βMon Jun 20, 2022 6:57 pmI was meaning wiring, not hydraulics!RobbiZ4 wrote: βMon Jun 20, 2022 1:46 pm No, part B61 is a short cable adapter for this microswitch coupling fastener to support an improved plug(!) format.
e85 3.0si sold
