Salmon Relay Change
Deepseaskateboard
Salmon Relay Change
Post by Deepseaskateboard » Wed Jun 22, 2022 11:50 am
RobbiZ4 wrote: Wed Jun 22, 2022 11:46 am
Deepseaskateboard wrote: Wed Jun 22, 2022 11:41 am I was wondering if anyone can see if the old relays look bad?
Just have a look at the link in my former post.
RobbiZ4 wrote: Sat May 14, 2022 3:16 pm Please have a look at the following link:
https://www-zroadster-com.translate.goo ... st-3124720
The date code from the picture is 2136, that is week 36 in 2021, less than a year old. What should we see? The risk of a destroyed hydraulic pump arises after 5-10 years.
The 2136 is the new one I put in.
Previous were 1202. (Original to the car)
tigor
Salmon Relay Change
Post by tigor » Mon Jun 27, 2022 11:05 am
I have a receipt from the previous owner of my car detailing…
‘Carried our diagnostic into roof fault and confirmed one side rear mech sensor is required however they require replacement in pairs.
Replaced osr and nsr micro switches for the rear lid compartment.’
Does this sound like salmon relay changes based on them failing?
2013 Z4 sDrive20i M Sport (28i map)
2022 X3 xDrive20i M Sport (hybrid nonsense)
RobbiZ4
Salmon Relay Change
Post by RobbiZ4 » Mon Jun 27, 2022 12:10 pm
tigor wrote: Mon Jun 27, 2022 11:05 am ‘Carried our diagnostic into roof fault and confirmed one side rear mech sensor is required however they require replacement in pairs.
OMG.
The explanation of a mandatory double-sided repair is nonsense! This instruction does not exist from BMW.
I'm pretty sure it was a broken wire as those switches in the roof shell almost never fail.
Nevertheless, where do you see a match between switch and relay?
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
tigor
Salmon Relay Change
Post by tigor » Mon Jun 27, 2022 2:01 pm
(Ordered a pair of relays)
DonDon
Salmon Relay Change
Post by DonDon » Sun May 21, 2023 1:31 pm
I am going to replace the salmon relays, just to be on the safe side.
I have seen a video that disconnects the negative terminal of the battery first. That seems like a sensible precaution (if somewhat over cautious), but there is no indication of whether there is anything to do once the battery is reconnected. Does anything get confused with just a few minutes' loss of power, or is it as simple as just reconnecting it?
2013 E89 28i auto
RobbiZ4
Salmon Relay Change
Post by RobbiZ4 » Sun May 21, 2023 1:43 pm
You don't have to do anything apart of simply replacing the two salmon relays by pull&push!
viewtopic.php?p=1892773#p1892773
And in general have a look at the following:
:ant:
DonDon
Salmon Relay Change
Post by DonDon » Sun May 21, 2023 2:00 pm
Herzlichen Dank!
2013 E89 28i auto
DonDon
Salmon Relay Change
Post by DonDon » Sun May 21, 2023 2:56 pm
Well that's the easiest £50 I've saved in a long time! I couldn't get the relays clear of the bracket without undoing the T20 Torx bolt. Once I did, it seems I was preempted by the previous owner just under a year ago.
2013 E89 28i auto
RobbiZ4
Salmon Relay Change
Post by RobbiZ4 » Sun May 21, 2023 4:20 pm
Top! :thumbsup:
:ant:
Fullspeedahead
Salmon Relay Change
Post by Fullspeedahead » Tue May 30, 2023 8:42 pm
Easiest job ever. Took 2 minutes 45 seconds (including discon/reconn the negative terminal).
RobbiZ4
Salmon Relay Change
Post by RobbiZ4 » Tue May 30, 2023 11:17 pm
Fullspeedahead wrote: Tue May 30, 2023 8:42 pm ...including discon/reconn the negative terminal.
Well, as this task is not required, it only took 10 seconds to replace the two relays. :driving:
:ant:
