Boot wouldn't close
step_change
Boot wouldn't close
Post by step_change » Mon May 03, 2021 5:06 pm
Drove off and got a warning the boot was open. "Huh......?" I thought, I hadn't been into the boot and it was fine yesterday when I locked it and parked up. Anyway, I tried to close it with the usual force required and the soft close would not engage after multiple attempts leaving the boot slightly (and clearly) open. I then thought I'd just juice it and slam it and it then closed and engaged. Odd. I then drove around and did my errands and gingerly tried it again a few times and it was fine.
I normally do not leave the car outside in the rain, the car is usually garaged and, as a general rule, I only use the car in the dry. Wonder if the wet and damp of this typical bank holiday has got to it in some way, although no signs of any leaks.
Anyway, all is fine now but wondering what could have been the matter? Any thoughts please? Will keep an eye on it.
Gone :( : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
Timmyboybunter
Boot wouldn't close
Post by Timmyboybunter » Mon May 03, 2021 6:53 pm
Could be the start of your soft close mechanism wiring giving up - worth a search, very common issue and fairly easy to DIY.
(though the symptoms in my case was the soft close action grabbing, releasing, grabbing, releasing etc - so possibly different)
2019 G21 M340i Touring xDrive
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
flybobbie
Boot wouldn't close
Post by flybobbie » Mon May 03, 2021 9:02 pm
My car boot has started catching when opening, as though the hooks aren't pulling back fully.
step_change
Boot wouldn't close
Post by step_change » Tue May 04, 2021 7:58 am
Thanks for the input. I shall investigate this. Searching around this thread comes up that you created flybobbie:
viewtopic.php?t=91766&start=15
...although it seems the start of the thread is missing as is the video.
flybobbie
Boot wouldn't close
Post by flybobbie » Tue May 04, 2021 8:24 am
step_change wrote: Tue May 04, 2021 7:58 am Thanks for the input. I shall investigate this. Searching around this thread comes up that you created flybobbie:
Sorry about that, but the thread has many examples of where the fault lies.
step_change
Boot wouldn't close
Post by step_change » Tue May 04, 2021 11:01 am
Yes mate I think I have fathomed it out from the pics, thanks. Need to have a look at this when I get some time. Doesn't seem to be doing it now but the fact that it did it even once suggests there is an underlining issue. I am a dab hand with soldering iron anyway so should be able to work it out.
step_change
Boot wouldn't close
Post by step_change » Wed May 05, 2021 8:27 am
Tested this about 40 times and it never did it again. Hmm, at least I know what to do now if it does reoccur more permanently.
QQ. Will the roof still open and close if the soft close boot mechanism is showing this issue? Last thing I want is to be out 100 miles away, I need to close the roof, and the soft close issue decides to reoccur..... :?
Smartbear
Boot wouldn't close
Post by Smartbear » Wed May 05, 2021 1:36 pm
step_change wrote: Wed May 05, 2021 8:27 am Tested this about 40 times and it never did it again. Hmm, at least I know what to do now if it does reoccur more permanently.
I would say if the boot closing mechanism malfunctions you’re stuffed.
All gone, now bouncing around in a deux chevaux
e85 3.0si sold
Timmyboybunter
Boot wouldn't close
Post by Timmyboybunter » Wed May 05, 2021 1:47 pm
Is the soft close mechanism (the bit affected by dodgy wiring anyway) involved in the roof up/down movement?
step_change
Boot wouldn't close
Post by step_change » Wed May 05, 2021 3:11 pm
Timmyboybunter wrote: Wed May 05, 2021 1:47 pm Is the soft close mechanism (the bit affected by dodgy wiring anyway) involved in the roof up/down movement?
That is my point. The boot lid mechanism is kind of additional to the roof mechanism, I can't see how it would effect it.
enuff_zed
Boot wouldn't close
Post by enuff_zed » Wed May 05, 2021 3:16 pm
step_change wrote: Wed May 05, 2021 3:11 pm
I'm sure someone like Robbi will be along to clarify, but I'd think it would check the boot was latched first before moving the roof. Otherwise it would be free to move when the back shell lifted wouldn't it?
HQ of 'Norfolk Zed Rescue'.
Timmyboybunter
Boot wouldn't close
Post by Timmyboybunter » Wed May 05, 2021 4:04 pm
Sorry, yes - engage my brain.
When I had the soft close error, it did first play up on me when I was picking the kids up from school. Roof was up at the time, but the (thankfully 10 minute) journey had the soft close mechanism grabbing and releasing constantly with a 'boot open' bong and warning message on the dash. When I got home I just gently laid the boot lid down - not far enough for the soft close mechanism to grab it, but it was water tight. No way the roof will function in that scenario though as the car knew the boot was open so as per earlier comment you would be buggered if the soft close went with roof down I would think.
step_change
Boot wouldn't close
Post by step_change » Wed May 05, 2021 6:32 pm
I will try to do operate the roof if the boot soft close thing fails to work. I am now on tenterhooks with the car and dare not operate the roof in case the soft close fails.
Pondrew
Boot wouldn't close
Post by Pondrew » Wed May 05, 2021 6:45 pm
Timmyboybunter wrote: Wed May 05, 2021 4:04 pm When I had the soft close error, it did first play up on me when I was picking the kids up from school.
Can't get rid of this image now:
2024 Audi A4 avant 40 black edition petrol
2025 Ford Focus ST 'track pack'. Go-kart with sat nav.
Z3 'free litre'. Project and a half.
No Z4 anymore!
Timmyboybunter
Boot wouldn't close
Post by Timmyboybunter » Wed May 05, 2021 6:57 pm
Ha, good point - Kid singular!
