Tip...knee pad removal
- CrazyOneToo
When removing these knee pads there are two recessed areas on the bottom to pry. See top photo with highlighted area.
The pry tool/screwdriver/knife should be held at an angle to go up into the recessed area of the console.
Not held flat against the console. Somewhere approximately at a 45 degree angle to the console plastic.
There is maybe 1/8 to 1/4 of an inch area of the knee pad that is sunk in and isn't visible when attached in place.
Meaning the knee pad is thicker than you can see.
These photos show the Left hand knee pad and the Right hand side of the console.
- IMG_20190921_1511102.jpg (109.91 KiB) Viewed 14773 times
- IMG_20190921_1509181.jpg (128.84 KiB) Viewed 14773 times
2007 E85 Z4 3.0Si Roadster with 6 speed manual...
2002 E53 X5 3.0i with auto...
1999 E46 328i sedan with auto...
- NickDE
I first read that as 'Tip...knee cap removal'. Then was very disappointed !
Darkness gone, Tronic gone, Solo gone, go Darknes2, go Frozen, go Black Pearl, Go Echo
- Chris_D
Sounds like you had someone in mind?NickDE wrote: Sat Sep 21, 2019 10:32 pm I first read that as 'Tip...knee cap removal'. Then was very disappointed !![]()
I’d have Trump, Blair, Bush Sr & Jr and Cameron kneecapped if I could.
- NickDE
A few people in mind, yeah !
- CrazyOneToo
- buzyg
Too good for them.
your pic shows the edge of an oddments net. could you post up a better pic and approx size..i've been searching for this and cant find them anywhere even new from BMW. thanks
- CrazyOneToo
Yes, I can take a photo for you also but this might help out more.terryo wrote: Sat Sep 28, 2019 10:51 am your pic shows the edge of an oddments net. could you post up a better pic and approx size..i've been searching for this and cant find them anywhere even new from BMW. thanks
I rarely find anything that ECSTuning doesn't have.
https://www.ecstuning.com/b-genuine-bmw ... 477116156/
many thanks for that...i just checked with them.... they have no stock and cant tell me if the clips are part of it or not,. nor could they give me a part number for the correct clip. i guess i'll keep searching.
- CrazyOneToo
The site linked below shows to have them also. And if you look at RealOEM.com you can find almost any part number.terryo wrote: Sat Sep 28, 2019 11:15 pm many thanks for that...i just checked with them.... they have no stock and cant tell me if the clips are part of it or not,. nor could they give me a part number for the correct clip. i guess i'll keep searching.
If yours is the same car as mine the link below shows the fasteners part number as 51472263062.
RealOEM is a great site for reference. On the main page just enter in the last 7 of your VIN to show your car info.
There are a lot of sites out there that sell BMW parts. If the sites below don't help I can list some others.
https://www.leatherz.com/collections/z- ... -net-small
https://www.realoem.com/
https://www.realoem.com/bmw/enUS/showpa ... Id=03_0500
https://www.ebay.com/itm/BMW-OEM-03-08- ... SwLsBZPzzO
again, many thanks. could i please have a pic of yours so i can work out if it is handed, left or right, or same part number should fit both sides. the parts list says no such accessory is available for my RHD car, but then i found a net # 51477116156 that supposedly fits my VIN with a 'warning vest"...go figure???
https://www.realoem.com/bmw/enUS/part?i ... 1470429466
- CrazyOneToo
I didn't take it apart but I assume the mounts (4) just need a hole made to screw into the carpet.terryo wrote: Sun Sep 29, 2019 9:57 am again, many thanks. could i please have a pic of yours so i can work out if it is handed, left or right, or same part number should fit both sides. the parts list says no such accessory is available for my RHD car, but then i found a net # 51477116156 that supposedly fits my VIN with a 'warning vest"...go figure???
- IMG_20190930_1238296_2.jpg (201.91 KiB) Viewed 14602 times
- IMG_20190930_1238197.jpg (212.29 KiB) Viewed 14602 times
great, thanks. that is different to every other BMW one can find. the angled front bar seems unique to the Z. I have found various sources for the clip.
- CrazyOneToo
terryo wrote: Tue Oct 01, 2019 11:56 pm great, thanks. that is different to every other BMW one can find. the angled front bar seems unique to the Z. I have found various sources for the clip.
- Z4C_er
Thanks for this great post. I removed my one today, but not before a lot of cursing. I used a butter knife (mentioned in another forum post) and it worked the best. You need something quite flat and strong. Anyway, there are 4 recesses to get into, but the two lower ones are the best. I got under the cover with the butter knife and prised it away from the console, then used a plastic trim removal tool to get under and remove the panel. What a pain...
I intend to put a little bit of silicone grease on the clips before clipping it back. hopefully, this will make it easier next time!
I hope the picture (in addition to CrazyOneToos post) helps to explain further:
2006.5 E86 Z4C si SE Phoenix Yellow
