Z4 Roof Doctor Required! - E. Midlands
Help! (please)
We have had a few issues with our 2013 Z4 (S Drive 18 M Sport Roadster Hard Top Convertible). First one of the gate sensors went but lately, the roof stuck halfway through the process (nightmare!) and then after a lot of hassle, our local Automotive Electrical Company managed to get it down and then change what I think was the command unit in the roof but as they haven't worked on Z4's before, they had to go through a painful learning curve.
Trouble is, even though it's repaired, we now have no confidence in the roof (at one point they said it 'may' need a part that could not be bought on its own as it came attached to a hydraulic part that would be circa 2K (gulp!) but luckily it didn't - phew! Its of such a concern (we have hood anxiety) that we are now reluctant to use the hood.
So, to regain our faith in the hood, I was hoping that someone (company) who had good experience of Z4 hoods could give it a thorough going over and make sure that it gives us at least a couple more years of worry free use. Yes, things could go wrong in that period but I'd feel so much better if it was looked at by someone who genuinely knew what they were doing and any suspect parts were replaced.
Would anyone know of any company in the East Midlands area that they could recommend? We live near Loughborough/Derby/Nottingham but would be prepared to travel anywhere in the East Midlands. Hopefully someone on the forum could help point me in the right direction. Thanks!
Eric Riley
Eric Riley
AnubisZed is based in East Midlands.
He might know a roof guy.
I’ll pm him to check this thread for you as you need 3 posts to send a PM
Thank you for the quick response! Any help you can give would be much appreciated!
- mr.tourette
Not used them myself and a bit further north but Hoodtech in Chester get good reviews https://hoodtech.co.uk/
- Ole gits rule
I would imagine most BMW specialist's would be able to go through the roof, gate sensor is that a microswitch?
M4 Vert in Yas Marina Blue
Thanks for the Hoodtech link, they look impressive! In regards to the gate sensor, then yes, I think you are correct, it's a microswitch. As you say, most BMW specialist's would be able to go through the roof but I'm really after a recommendation of who to use and ideally, someone near the East Midlands.
- RobbiZ4
Interesting thought, but lightyears apart of the reality.Ole gits rule wrote: ↑Sat Aug 14, 2021 9:39 pm I would imagine most BMW specialist's would be able to go through the roof, gate sensor is that a microswitch?
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
Hi Eric,RileyRennocks wrote: ↑Sat Aug 14, 2021 9:50 pm Thanks for the Hoodtech link, they look impressive! In regards to the gate sensor, then yes, I think you are correct, it's a microswitch. As you say, most BMW specialist's would be able to go through the roof but I'm really after a recommendation of who to use and ideally, someone near the East Midlands.
Is that near enough to the East Midlands?
https://www.staiger-neuffen.de/bmw-z4-e ... notdienst/
Unfortunately your description is not that exact to get an idea, what could be missing or should be replaced.
- Ole gits rule
Master techs should be able to sort that out, there are three by me and would trust all of them with Forza GB being the bestRobbiZ4 wrote: ↑Sat Aug 14, 2021 9:56 pmInteresting thought, but lightyears apart of the reality.Ole gits rule wrote: ↑Sat Aug 14, 2021 9:39 pm I would imagine most BMW specialist's would be able to go through the roof, gate sensor is that a microswitch?
- RobbiZ4
Are we talking about the E89 retractable hardtop or generally about BMW cars? The latter, I would agree.Ole gits rule wrote: ↑Sat Aug 14, 2021 9:59 pmMaster techs should be able to sort that out, ...RobbiZ4 wrote: ↑Sat Aug 14, 2021 9:56 pmInteresting thought, but lightyears apart of the reality.Ole gits rule wrote: ↑Sat Aug 14, 2021 9:39 pm I would imagine most BMW specialist's would be able to go through the roof, gate sensor is that a microswitch?
- Ole gits rule
Microswitch are £16 each and in all honesty mine went a few weeks ago and the garage said it was all sorted, on collection went to drive off and the red light was flashing and roof not working.RileyRennocks wrote: ↑Sat Aug 14, 2021 9:50 pm Thanks for the Hoodtech link, they look impressive! In regards to the gate sensor, then yes, I think you are correct, it's a microswitch. As you say, most BMW specialist's would be able to go through the roof but I'm really after a recommendation of who to use and ideally, someone near the East Midlands.
They spend 45 minutes realigning it and seems to be working ok now.
On the first failure which part of the process stopped?
- Ole gits rule
e89 - yes some will be useless but most should have a clue where to bloody start and should know the most common problems are microswitch and hall sensorsRobbiZ4 wrote: ↑Sat Aug 14, 2021 10:02 pmAre we talking about the E89 retractable hardtop or generally about BMW cars? The latter, I would agree.
- RobbiZ4
OK, UK seems to be a paradise for E89 owners.Ole gits rule wrote: ↑Sat Aug 14, 2021 10:05 pme89 - yes some will be useless but most should have a clue where to bloody start and should know the most common problems are microswitch and hall sensors
In Germany, hardly any of the garages as well as of the BMW palaces has any clue about roof issues and strategies to get it solved.
- Ole gits rule
Absolutely not a paradise Robbi, never said that but still think most should have some clue if they have worked at BMW in the last 5 years.RobbiZ4 wrote: ↑Sat Aug 14, 2021 10:19 pmOK, UK seems to be a paradise for E89 owners.Ole gits rule wrote: ↑Sat Aug 14, 2021 10:05 pme89 - yes some will be useless but most should have a clue where to bloody start and should know the most common problems are microswitch and hall sensors
- RobbiZ4
Well, you are always using "should". I've got the complete different experience from all over our country.Ole gits rule wrote: ↑Sat Aug 14, 2021 10:21 pmAbsolutely not a paradise Robbi, never said that but still think most should have some clue if they have worked at BMW in the last 5 years.RobbiZ4 wrote: ↑Sat Aug 14, 2021 10:19 pmOK, UK seems to be a paradise for E89 owners.Ole gits rule wrote: ↑Sat Aug 14, 2021 10:05 pm e89 - yes some will be useless but most should have a clue where to bloody start and should know the most common problems are microswitch and hall sensors
