Bloody Brexit
e89 roof problem
- Ole gits rule
e89 roof problem
M4 Vert in Yas Marina Blue
e89 roof problem
See I told you I wasn't technical
Anyway, where are these resistors?
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Ole gits rule
e89 roof problem
Resisting showing up
- RobbiZ4
e89 roof problem
Here it is.
Before BREXIT:
- 5620 => 562 ohms times 10 exp 0 = 562 ohms
- 2211 => 221 ohms times 10 exp 1 = 2210 ohms
The microswitch coupling lock:
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- Ole gits rule
e89 roof problem
Defo missing off Pondrews image - very strange
- Argyll Andy
e89 roof problem
Some feckers got to his and stole them. Maybe this is the new Cat thefts for precious metals
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
e89 roof problem
Ok, so the German (eu) switches are different to ours, I think we've now established that.
This now poses another question; why? Or did they install resistors after a certain date?
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- RobbiZ4
e89 roof problem
These SMD's are a substantial part of all roof microswitches, it doesn't work without it.
Just have a look on your floor or in the garbage of the cut housing.
- Ole gits rule
e89 roof problem
The solder is still there so really odd that the centre pieces are missingArgyll Andy wrote: ↑Fri Jul 30, 2021 11:16 pmSome feckers got to his and stole them. Maybe this is the new Cat thefts for precious metals
- RobbiZ4
e89 roof problem
Same thought.Ole gits rule wrote: ↑Fri Jul 30, 2021 11:36 pm The solder is still there so really odd that the centre pieces are missing
As the whole block was potted, both resistors were cut out while opening. That can happen very easily.
e89 roof problem
Not "yet" had a problem with these switches in 12 years, but soon after acquiring the car, i liberally sprayed all the switches and mechanism with some silicone spay.
Is the green part of the switch hard or a rubber boot?
- Ole gits rule
e89 roof problem
They are quite brittle so will have come off with the resin seems the only optionRobbiZ4 wrote: ↑Sat Jul 31, 2021 7:01 amSame thought.Ole gits rule wrote: ↑Fri Jul 30, 2021 11:36 pm The solder is still there so really odd that the centre pieces are missing
- RobbiZ4
e89 roof problem
I would NOT recommend this!
The main problem of these faulty components are cracks in the housings. That will happen regardless what you try to "improve" with any spray. But most sprays will destroy more than expected (i.e. WD40).
Yes, the green parts are rubbers boots.
e89 roof problem
I have another one, so now i'm going to have to rip that one apart (more carefully admittedly) to see.
Maybe that's why I had to change them?
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- RobbiZ4
e89 roof problem
