The dreaded roof issue has come calling !
Hi everyone ,
Fairly new member so please be patient!
I have what I hope is a common roof issue, whereby on opening the roof from the switch, it opens without fault until the boot lid closes (with roof fully stored correctly) and then when it’s fully down the ‘bong’occurs and windows will not close.
Then on closing, the roof works perfectly until window section is on top of roof section , boot hatch closes correctly then ‘bong’ roof will not drop into position !
The rear deck closes fully as it always has,but you can almost tell it thinks it hasn’t , so I give a sharp/hard push, down on to the black surface which the window section closes onto ( nothing actual happens that I can see as it is fully closed) and the roof then carries on in the normal way in both closing/opening mode.
Now after some digging around the net , and some fantastic info on this site from various members, Im thinking it’s the microswitches and not the hall sensors on the the ram. I’m going to check the connections firstly , then proceed to buy the switches/ sensors.
The hall sensors are ridiculously expensive to say the least. A little further digging found that the hall sensors from a 1 series can be chopped and soldered to suit . Is this method still ok to do , as they look identical, minus connector.
Lastly I maybe/possibly to blame as literally the week before I liberally lubed all the moving parts of the hinges etc, and I’m now pretty sure I have inadvertently got lube in the micro switches under the rear deck hinges
Please ridicule away , I’ve learnt the lesson in all this !!
But before I tinker further ANY help/further advice will be warmly welcomed.
Andy
Andy
F31 330d Daily
E89 35i weekend
Evoque gone
Aston vantage v8, missed
Porsche Boxster s,gone
- Chippie
I’m no expert and not had any problems with mine but from what you have said I think you are correct about it being the micro switch’s and that would be the first thing I would check, you could try spraying some electrical cleaner on them it may help remove any oil contamination in the switch
Hi yes that’s my thinking , I am going to try the contact cleaner also I’ve got some servisol contact cleaner so yes I will also try that
F31 330d Daily
E89 35i weekend
Evoque gone
Does sound like the failure mode I have which it is asserted to be one or both of the micro switches next to the rams in the boot as you suggest.
Mine has mysteriously fixed itself as the temperatures warmed up..have the switches ready to fit now but waiting for a permanent fault...
- 4CCD29EA-3AB9-4B71-8914-CC632E03BE41.jpeg (189.84 KiB) Viewed 2875 times
- 22224174-F986-448E-ADAA-C27B300AA6F8.jpeg (75.74 KiB) Viewed 2875 times
- RobbiZ4
Hi Andy,304frp wrote: ↑Sun Apr 18, 2021 8:25 am I have what I hope is a common roof issue, whereby on opening the roof from the switch, it opens without fault until the boot lid closes (with roof fully stored correctly) and then when it’s fully down the ‘bong’occurs and windows will not close.
Then on closing, the roof works perfectly until window section is on top of roof section, boot hatch closes correctly then ‘bong’ roof will not drop into position !
exactly the typical issue with the 2 microswitches on top of both rams of the lid. Have to be replaced.
What a nonsense!
As several times stated before: never ever think about any lubrication in the roof's mechanic! The often quoted YouTube video should be dropped ASAP.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
There is a kind of corrosion inside of these two switches. The signal to the CTM might be random depending on the weather, temperature, time of day or whatever!Pbondar wrote: ↑Sun Apr 18, 2021 9:02 am Does sound like the failure mode I have which it is asserted to be one or both of the micro switches next to the rams in the boot as you suggest.
Aha thanks..looking at the design with the rubber seal I had hoped for their to be a stable environment within the switch.RobbiZ4 wrote: ↑Sun Apr 18, 2021 10:17 amThere is a kind of corrosion inside of these two switches. The signal to the CTM is a randomly depending on the weather, temperature, time of day or whatever!Pbondar wrote: ↑Sun Apr 18, 2021 9:02 am Does sound like the failure mode I have which it is asserted to be one or both of the micro switches next to the rams in the boot as you suggest.
This kinds of explains the issue I’m suffering...
Long periods of inactivity plus we have had a very cold / damp winter would lead to such corrosion both forming and not being ‘cleaned’ by the switch action...I assume a combination of use and warmer much dryer weather has temporarily mitigated the issue.
Anyway got the switches now so will either wait for a more sustained failure and/or wait till next winter then tackle it myself when I’ve built my garage
- RobbiZ4
Interestingly, there is absolutely no known issue with the original, small plugs on those microswitches. I don't have any clue, why somebody at BMW or EDSCHA has replaced these plugs with sealed ones.
The corrossion happens INSIDE of the switches, not on the plugs.
Tip for mounting the new sealed plugs on the old E89 loom:
- don't even think about buying those expensive adapters, that BMW offers. You have to solder those adaters anyway!
- carefully unplug and remove the black 'n white plug housings from the old microswitches
- destroy(!) the new plugs with a small side cutter
- pinout those 2 new pins
- push the green seals back and out of the new pins
- re-crimp the 2 new pins to reduce the diameter
- put these reworked, new pins into the old white and black plug housings
Got it..thnx!RobbiZ4 wrote: ↑Sun Apr 18, 2021 11:09 amInterestingly, there is absolutely no known issue with the original, small plugs on those microswitches. I don't have any clue, why somebody at BMW or EDSCHA has replaced these plugs with sealed ones.
Tip for mouning the new sealed plugs on the old E89 loom:
- push the green seals back and out of the contact
Great info , thanks , off to bmw on Monday !.
F31 330d Daily
E89 35i weekend
Evoque gone
RobbiZ4 - good to see you back on the forum. Personally I always enjoy reading your posts as they are very informative, I dont have too much experience with the e89 Z4.RobbiZ4 wrote: ↑Sun Apr 18, 2021 10:14 amHi Andy,304frp wrote: ↑Sun Apr 18, 2021 8:25 am I have what I hope is a common roof issue, whereby on opening the roof from the switch, it opens without fault until the boot lid closes (with roof fully stored correctly) and then when it’s fully down the ‘bong’occurs and windows will not close.
What a nonsense!
- Zed Baron
Is there a specific reason why not to lube any of the hinges etc I used a dry lube / ceramic that I use on my cycle chains didn’t think much of it really , the boot hinges did have rust , dust around the moving parts .
F31 330d Daily
E89 35i weekend
Evoque gone
- Smartbear
I remember reading that the hinges have phosphor bronze bushes which shouldn’t be lubricated.
e85 3.0si sold
- RobbiZ4
Yes, there is.
Correct.
The "rust" mentioned before is from the special bearing bushes in all joints. IT IS NO RUST. Each critical joint is protected by these bearing bushes. The source of the red "rust" flakes can be seen on the following picture. You achieve exactly the opposite of your original idea with lubrication:
Dust gets bound.
https://www.zroadster.com/forum/threads ... st-3055778
