- diag_46o6.jpg (40.86 KiB) Viewed 1313 times
- Screen Shot 05-22-20 at 12.59 PM.PNG (9.32 KiB) Viewed 1313 times
thanks
The problem seems to be with the "rear module microswitch" (that's what it's called in the workshop manual) or what I've been calling the "boot lid" not knowing it has succesfully closed, which is what RobbieZ4 and dietcokeman seem to agree is due to the boot lid or "rear module" microswitch - #4 and #5 in the diagram. The parts catalogue seems to call this the "ring buckle coupling microswitch" but I'm pretty sure it is the same thing.tintoverano wrote: ↑Fri May 22, 2020 12:03 pm diag_46o6.jpg
how about #2 and #3?
thanks
just wanna order the rigth oneswanatkinson wrote: ↑Fri May 22, 2020 2:03 pmI can see why you would look at the rear window shell as that is the part that is stuck when trying to close the roof, but the problem is still present when the roof is fully open and the rear window shell is stowed away, i.e. the wndows won't go up, the boot is locked and the warning light and sound remain.tintoverano wrote: ↑Fri May 22, 2020 12:03 pm diag_46o6.jpg
thanks
Hi, the microswitch spring which seems to cause problems due to stretching - is it possible to replace the spring only or maybe shorten it by cutting 1 coil off & reattach? (both sides of course)RobbiZ4 wrote: ↑Fri May 22, 2020 11:35 amThat's my general recommendation for all 2009/2010 Z4.wanatkinson wrote: ↑Fri May 22, 2020 11:27 am I think I will replace these first and see what happens
Apart of your individual issue, these MS can fail due to the aging of that little spring on the microswitch, that is spreaded to max when the lid is closed. And that is 99.9999999% of the lifetime of the Z4.
And, these failing MS can force the hydraulic pump to run continuosly until it dies due to overheating. That situation is not checked by the CTM.
There are some pifalls:
- mark the exact position of the 3 nuts on the coupling locks, use a fine white or silver edding pin to mark around these nuts
- the small 3 mm inbus(!) screws are glued and in most cases have to be drilled out with a 3mm drill
- you need 4x M3 inbus screws with a lenght of 10mm, two of them have to be shorted to a lenght of 5mm
- the new microswitches have a newser plug. Cut the new(!) plug housing, take the pins out of it and put it into the housings of the old MS
Just have a look at the position, whre the MS are mounted. If you will get a 5mm spring replaced there, you will be my hero.
It wasn’t the cost that concerned me, just sounded like a fiddly/awkward job. Changing the spring only sounds like an equally unpleasant task!
Thanks for the link, seems like an awkward job for me, I wonder if the Indi specialist here can do it.
hi Robbi,
Robbi has picked up his ball and gone I'm afraid.tintoverano wrote: ↑Mon Jun 01, 2020 9:38 amhi Robbi,
as you mentioned the allen screws holding the microswitch are glued too and had to be drilled out (I'll try to find a driver with more rigid head on Tuesday, sse if I can release them - the one I had failed)
if not, what are the specs of theses screws?
I don't see them listed
thanks
Hello tintoverano,tintoverano wrote: ↑Mon Jun 01, 2020 9:38 amhi Robbi,
thanks
