Roof fault
Roof fault
Just to add to that as a precaution to members with a similar issue, dont mash on the roof up and down button, should the relays fail.
This relay issue can cause your motor to overheat and explode.
Roof fault
Don't think that will happen as there is a thermal cutout, unless that goes faulty.
What puzzles me is the fault codes that came up saying that 5 or 6 sensors on the roof were faulty, when they all worked fine.
My business partner had a 2012 car with only 8k miles and it's roof was constantly failing, even though BMW replace probably all the micro switches on three separate visits. When fixed they said they had cycled the roof many times without problem.
Yet when driven away and used for a few weeks, the roof would fail again.
If on failure all they were doing was reading the codes and then just replacing the (faulty) sensors, then finding the roof was working, was that just coincidence?
The relays i replaced worked fine on the bench.
Or is there something wrong with the controller?
Or is it a symptom of the power cable call backs BMW have instigated.
I have ignored the call back, but perhaps should have it done.
- RobbiZ4
Roof fault
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
Roof fault
- RobbiZ4
Roof fault
Roof fault
Are you a rocket scientist in your spare time?RobbiZ4 wrote: ↑Thu Apr 11, 2019 11:48 am This is an EKG of the opening sequence of all microswitches and hall sensors:
With this tool I'm able to identify component or wire failures even if the roof doesn't work anymore.
Let's have a diagnostic session here in Munich to check your roofs.
Serious respect!
- RobbiZ4
Roof fault
Roof fault
Those graphs seem to tie in with the readout on the Foxwell reader i have.
Early cars like mine have 3 solenoids yet the later models seem to have 4.
The later wiring diagrams show a 4th solenoid.
- 3.jpg (65.53 KiB) Viewed 1404 times
- RobbiZ4
Roof fault
Roof fault
https://drive.google.com/file/d/0BxW-0N ... 9KM1k/view
No idea original source.
Wiring diagrams seem a bit easier to understand than Tis.
The Foxwell just a reader but also shows real time graphs.
Only just got into it, to fix my roof problem.
I wonder if the new solenoid anything to do with operating the roof on the move.
- RobbiZ4
Roof fault
Roof fault
Yes full wiring diagrams are much better when trying to understand a total system.
- 2011BlackZ4
Roof fault
I have a roof opening problem too, the roof will stack the rear window on the roof but not open the boot, I'm not sure if the boot not opening is blocking the roof unlocking or the roof not unlocking at the windshield is blocking the boot opening. We can shut car off, pull key , lock car, unlock car, restart and the roof will let me reverse/close the roof back down and lock roof in rear so I can drive as a roadster. I have a little OBDII reader but it hadn't thrown any codes, BMW dealership replaced one of the microswitches on the right side/passenger side but that didn't fix. I think the wire bundle got out of the channel when a ziptie broke. We found one brown wire that was broken and resoldered in the right arm holding the rear window. After reading posts, maybe try replacing relays attached to pump? Open to any other suggestions, thanks
- RobbiZ4
Roof fault
- enzed4
Roof fault
Sorry if this has been posted - I think it might be in one of RobbiZ4's German threads?
Is this the part we should be looking at replacing (the salmon relays - two of them):
BMW part number 12631742690 (12 63 1 742 690)
Thanks.
Thanks.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
