Remove the indicator (gentle pressure in, and twist), then use a plastic credit card, or thin nylon string under the badge edge. Don't use a knife as it damages the badge. Also, you may want to mark the top of the indicator before removing the badge, otherwise you will put them back wonky
Double sided tape - Halfords number plate tape would work well (not the really thick stuff though!). You can pick up double sided tape from eBay for a few quid...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
