Quick update on the car as I suppose this is now a diary instead of strictly about the wrap!
Got a replacement emergency kit as mine was missing from previous owners
Hard wired in my dashcam. Line is run along the A pillars and into the fusebox on the passenger (LHS) footwell area.
Also wired in a cheeky LED into the glove box (hooked in with the interior lights).
Gloss black plastidipped my mirrors. I have planned to try using Autodip instead but seeing how this plastidip holds up since I sprayed it already.
Did the roof motor relocate! This was a pretty annoying job to do just because of the contortionist style positions you need to be in!
Here's some pics in case there's a helpful angle for someone else when they're searching (I know i tried to find lots of pics myself before starting).
Mine had some foamy stuff around it.
Foamy stuff removed
I found the best way (for me at least) to take off the top cover (of the motor housing) was to stick my arm in from the passenger side (LHS). This way I could pull upwards instead of having my arm in a weird non-leveraging way from the boot.
With the top cover off, you still won't be able to pull the motor out all the way to the boot as the lines are looped UNDER the lower housing. This is how far you'll get:
You'll just need to man-mode it and rip that F***KER out with all your strength (if your tab isn't broken like mine). It took me 2 hours of meddling - trying to locate the cable tie; use a camera to navigate etc.... - then just gave up and decided to just absolutely wring at it. Turns out that was the best way. There's no tips here really just... yank it as hard as you can until it breaks!
This is the clip/hoop you're trying to break off:
Here's the drain hole UNDER the housing:
After that it's just a case of following the instructions that forum pioneers have written
I reused my lower housing to sit the motor. Still need to sort out a piece of carpet trim but it's working great!
And my most excited up-coming thing is... a new soft top!
My car had a tear in it that was patched by the previous owner and I've somehow lived with it for the past few years. It constantly bothered me as I am quite a fastidious person - my previous car that I had from new was (pridefully) kept absolutely immaculate inside and out. Reason I didn't do it before was there just didn't seem to be any guides on how to replace the soft top (just the skin and not the entire roof). But somehow the other day while trying to search again, I found a PDF from Autotops that a member on Zpost had posted. Don't know why this thread never came up on my search in the past! Link here (
https://www.zpost.com/forums/showthread.php?t=968789)
So I ordered a Sierra one and it'll be here in a few weeks from the US. To say I'm excited is an understatement!
Here's what it looks like right now:
But before I can get to the top when it arrives, I need to sort out my VANOS service which I have been avoiding like the plague. I have run some basic diagnostics with my C110 and it does appear there's NO advancement/retardation of the cams which I am assuming means its borked (as expected).
The adaptation angles never move - not a nth - while the position % do vary but very abruptly. It would be on 31% and suddenly drop to 0% when I off throttle after WOT and back to 31%. No idea if that's normal either but regardless, this will be a cool experiment to see if this cheap diagnostic tool can be used to preliminary check VANOS function. I will of course check it again after I have replaced the seals to see what the readings change to.
Would be really disappointing and awkward if... nothing changes
