E89 rear drivers side window not working
WestSussexZ4
Post by WestSussexZ4 » Sun Mar 03, 2024 7:10 pm
Hi All,
Just in time for the UK spring weather my rear drivers side window has stopped working, halting me enjoying roof down motoring!
I can hear clicking but no movement or motor noise. I suspect regulator has broken / seized.
Any other suggestions / advice on how I access the regulator? I've searched the Internet and can't find any guides so is perhaps quite uncommon?
Adam
2k35is
Post by 2k35is » Sun Mar 03, 2024 8:00 pm
Had same problem on mine could hear clicking noise for both up and down press of switch but no movements. I got a can of WD 40 with a straw spay extension and poked it between glass and rubber and move it about to give a good dosing from both inside and outside of car. Left it overnight - tried in next morning and worked fine-never happened again.
Like you I couldn't find any info on ho to remove interior trim to get at at window workings.
Hope it works on yours.
Dec 2009 Z4 35i DCT Deep Sea Blue
2018 3 door Cooper S DCT
sold 2003 e46 330ci Convertible
WestSussexZ4
Post by WestSussexZ4 » Sun Mar 03, 2024 8:07 pm
Thanks mate, will give it a go!
WestSussexZ4
Post by WestSussexZ4 » Mon Mar 04, 2024 9:04 am
Sadly no luck with this. Any further advice from anyone welcome 🙂
RobbiZ4
Post by RobbiZ4 » Mon Mar 04, 2024 7:13 pm
Well, in that case a code reader might be helpfull. The ISTA tool will even display the current positions of the windows.
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
WestSussexZ4
Post by WestSussexZ4 » Sat Apr 06, 2024 6:39 pm
Hi All,
Just got the z4 back from the garage.
Blocked drain holes causing the regulator to sit in water and seize.
Second hand regulator and motor from ebay and 4 hours labour and the problem is fixed.
Thank you all for your advice and enjoy the summer.
Adam
Busterboo
Post by Busterboo » Sat Apr 06, 2024 8:55 pm
So, thick end of £500, then?
Vidi, vici, veni
WestSussexZ4
Post by WestSussexZ4 » Sat Apr 06, 2024 9:02 pm
Yes, just under incl vat and the part.
RAYK47
Post by RAYK47 » Sat Apr 06, 2024 10:59 pm
WestSussexZ4 wrote: Sat Apr 06, 2024 6:39 pm Hi All,
Adam
Where exactly on the E89 are the drain holes? I have searched here and seen references that there are not any on an E89.
However I thought I had a leak and the garage said they couldn't find anything but cleaned out the drain holes. I have not had any issues since.
Zed Baron
Post by Zed Baron » Sun Apr 07, 2024 2:08 am
RAYK47 wrote: Sat Apr 06, 2024 10:59 pm Where exactly on the E89 are the drain holes? I have searched here and seen references that there are not any on an E89.
I didn't think the E89 had drain holes either, totally different design to the E85.... where are they?
RAYK47
Post by RAYK47 » Tue Apr 09, 2024 8:44 pm
I wish I knew. Maybe I should ask the mechanic
