i screenshotted it all anyway so your pettiness was in vain work on your people skills next time
bmw z4 28i m sport 2015 model cant get into the boot no battery inside
Robert you have pissed off the forum roof and electrics expert who has helped many on here and probably saved us 10s of thousands of pounds in roof diagnostics and repair. I suspect you are in a bit of a panic, been there myself, feeling totally out of options
Everything he said was a warning to tread carefully things can go from bad to worse if you take the wrong steps. He is German and a bit Direct .
The good thing, he confirms the pin 12 trick which was linked on the first page of your thread should work, so read up on that.
I have used it myself so ask questions if you need to.
*12 April 2024, Just spotted i'm the culprit who wrote pin 15 trick, corrected to 12!
- RobbiZ4
Thanks for this excuse and coronation.
Well, Iβm not βdirectβ because Iβm German.
But I will argue very loudly and directly to prevent people who panic from drifting down the path of violence against our beloved E89.
This Z4 needs no chainsaw, no hole digged into the trunk, no violence. It's a little diva with lot's of electronics, which has to be orchestrated.
I'm an electronics engineer.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
Just a suggestion if the person cannot open the boot.
The trim is replaceable, if not up gradable.
- RobbiZ4
Agreed of course, but it's the wrong direction.
To check the tyre pressure, you can also cut it open and measure the volume. They are replacable as well.
It's a valid option.
Not needed the hole is already there behind the cabin bulkhead trim, just remove the trim.robertlancaster1094 wrote: βThu Feb 15, 2024 10:13 pm i got a mechanic to try everything on it today with the terminals under the bonnet etc and he said im gonna have to contact an auto electrician , also i thought of another idea is it safe for me to cut out the metal panel behind the seats and installing my own ski hatch for boot access
By the way volume and pressure are two different thing.
Something can have volume......but be vacuous...
I would even suggest reason why hole is there, gain access to the boot.
Ski hatch just secondary idea.
- RobbiZ4
An upgrade to integrate the ski hatch is another topic and not required as a roof repair option.
But to get the trunk opened, only two thin wires are required as far as the rear central locking motor is in a working condition. Ignoring this is a valid option.
i did nothing to piss him off he started being rude to me first trying to say i didn't mention the water leak making sarcastic rude comments that's not being direct its just making up lies cos i said in my original post that i had a water leak, he then went on to blame me for the issue all together when the rescue recovery person is the one who told me to remove the battery and as someone who doesn't know and been informed by a mechanic that i am ok closing the boot there would have been no way of me knowing that he was incorrect so if he is just coming on here to bully people due to their lack of knowledge i want nothing to do with him, i took heed of his advice and was good advice and i had no issues with him till he couldn't help but be rude because he didnt read my original post properlyStash36 wrote: βSun Feb 18, 2024 8:17 am Robert you have pissed off the forum roof and electrics expert who has helped many on here and probably saved us 10s of thousands of pounds in roof diagnostics and repair. I suspect you are in a bit of a panic, been there myself, feeling totally out of options
The good thing, he confirms the pin 15 trick which was linked on the first page of your thread should work, so read up on that.
he's clearly got a chip on his shoulder he probs works for bmw or something and helped create this terrible design fault
oh right well that's another option thanks for the adviceflybobbie wrote: βSun Feb 18, 2024 11:12 amNot needed the hole is already there behind the cabin bulkhead trim, just remove the trim.robertlancaster1094 wrote: βThu Feb 15, 2024 10:13 pm i got a mechanic to try everything on it today with the terminals under the bonnet etc and he said im gonna have to contact an auto electrician , also i thought of another idea is it safe for me to cut out the metal panel behind the seats and installing my own ski hatch for boot access
the 15 pin trick does sound like a good idea my fusebox is behind the glove compartment i checked my manual so ill have a look but might just get an auto electrician in if it looks too confusing im just weighing up all my options so i dont end up spending a fortune and as for anything that involves damaging the car too get in the boot is an absolute last option, but im assuming if the fusebox method doesnt work then there must be something else electronically wrong like the fuse being blown which would mean getting into the boot and putting the battery in is irrelevant would you agree?Stash36 wrote: βSun Feb 18, 2024 8:17 am Robert you have pissed off the forum roof and electrics expert who has helped many on here and probably saved us 10s of thousands of pounds in roof diagnostics and repair. I suspect you are in a bit of a panic, been there myself, feeling totally out of options
- enuff_zed
Robbi, I am sure you have a good enough sense of humour to take this in the manner it is intended:RobbiZ4 wrote: βSun Feb 18, 2024 11:16 am An upgrade to integrate the ski hatch is another topic and not required as a roof repair option.
It's been quite a while since a Lancaster last upset a German quite this much.
Having read through all this thread, please do understand that there are a lot of people on here who do appreciate your input, listen to what you say and consequently have saved themselves a fortune.
Keep up the good work. Thank you.
PS. I am also struggling to work out why the Pope joined up just to slag you off.
