bmw z4 28i m sport 2015 model cant get into the boot no battery inside
robertlancaster1094
Post by robertlancaster1094 » Sun Feb 18, 2024 1:50 pm
enuff_zed wrote: Sun Feb 18, 2024 1:40 pm
robertlancaster1094 wrote: Sun Feb 18, 2024 1:38 pm
enuff_zed wrote: Sun Feb 18, 2024 1:34 pm
What???!!!
You really wrote that?? :rofl:
I honestly think that should be reported as borderline racism. :headbang:
nationality isnt a race so it wouldnt be borderline or in any way racism
When you finally bludgeon your boot open, would you mind awfully just climbing inside and shutting it again. :rofl:
and im assuming there is no interior boot release either on this TERRIBLE design made by ze germans
RobbiZ4
Post by RobbiZ4 » Sun Feb 18, 2024 1:54 pm
robertlancaster1094 wrote: Sun Feb 18, 2024 1:50 pm and im assuming there is no interior boot release either on this TERRIBLE design made by ze germans
Of course not. With or without Roberts in the boot, it's definitely not required. :rofl:
robertlancaster1094
Post by robertlancaster1094 » Sun Feb 18, 2024 1:56 pm
RobbiZ4 wrote: Sun Feb 18, 2024 1:54 pm
what if someone is being kidnapped
RobbiZ4
Post by RobbiZ4 » Sun Feb 18, 2024 2:05 pm
bte123
Post by bte123 » Sun Feb 18, 2024 2:12 pm
I did the 12pin trick just last week as I was in an almost identical situation. My battery was completely dead so I used a jumper kit on the terminal under the bonnet tonite at least some charge through the car.
Then the wire on the two points of the fuse box (the black 12 pin block you need is slotted into the rear of the fusebox once you have access to it) and the boot popped open - after hours of panic and fiddling the sound of it opening was glorious.
If you need any help when doing it feel free to message me. I'm still in a mess as my FRM module is now broken I suspect, which can happen if the battery gets disconnected for too long or in other certain situations or so i I've read - hopefully this isn't the case for you. If it is there are some easy options for recoding it through eBay.
Good luck, try and enjoy your holiday for now ☺️
robertlancaster1094
Post by robertlancaster1094 » Sun Feb 18, 2024 2:13 pm
RobbiZ4 wrote: Sun Feb 18, 2024 2:05 pm
robertlancaster1094 wrote: Sun Feb 18, 2024 1:56 pm what if someone is being kidnapped
Would say, the E89 is not the perfect car for this task.
Even to press a tiny guy into this small trunk will be a hard piece of work.
That intention is like using the chainsaw to get INTO the trunk. :rofl:
not being a good car for the task would make it a good car for the task keeping it under the radar of suspicion and the terrible design of them not being able to get out makes it a good car for the task as a lot of cars now have kidnap escapes. A small person such as yourself would easily fit inside
robertlancaster1094
Post by robertlancaster1094 » Sun Feb 18, 2024 2:16 pm
bte123 wrote: Sun Feb 18, 2024 2:12 pm I did the 12pin trick just last week as I was in an almost identical situation. My battery was completely dead so I used a jumper kit on the terminal under the bonnet tonite at least some charge through the car.
thanks when i am back home i will take a picture of the fusebox when i get to it and see what you guys think before taking any action, i bet it was a breathe of fresh air hearing the boot release ive never been so stressed about my car before
bte123
Post by bte123 » Sun Feb 18, 2024 2:49 pm
robertlancaster1094 wrote: Sun Feb 18, 2024 2:16 pm
i 'might' have done a little dance around the car park! whilst there is good guidance on the forum on this topic already it really is a case of 'when you know, you know' sometimes because the diagram of the fusebox from the technical spec photo can be a little difficult to understand for a novice like me.
you'll need a small length of copper wire or something which will carry the charge between the two points on the fuse box.
some quick tips:
i found it much easier to remove the fusebox from the extending arm stem that it is on to get to the black 12 pin connector that needs to be removed.
you might have to disconnect a socket around the fusebox to make it easier to remove, this isn't always the case but it was for me just because of the the way that some very chunky groups of wires were positioned - they just needed to be plugged back together before replacing it.
as soon as i got the boot open i put it into service mode - this means pushing the two metal elements backwards to their locked position with a screwdriver or similar - they're located on the underside of the boot lid and if you need help / can't find them when doing it just reach out or search the forum for 'service mode boot'. its a really helpful trick to know about if ever you need to service the roof or remove / replace the hall sensors which i had to do last summer.
all the best from Wales :)
john-e89
Post by john-e89 » Sun Feb 18, 2024 3:45 pm
So how do you get the boot open if the battery’s dead or missing…?
MR2 MK 2
E89 35is
G29
flybobbie
Post by flybobbie » Sun Feb 18, 2024 5:45 pm
robertlancaster1094 wrote: Sun Feb 18, 2024 1:37 pm
RobbiZ4 wrote: Sun Feb 18, 2024 1:29 pm May I post a short summary for your 3 minutes task?
1 loaded battery
2 wires from the battery terminals, one to ground (earth - however you name it), the other with a needle or MQS pin to pin 12 of the removed 54pole plug below the junction box ECU sitting left of the front fuse panel
0.5 seconds of contact will activate the central locking motor of the trunk lid
:thumbsup:
ok thanks
Wow....
If this advice had been said on 2nd or 3rd post perhaps a international incident could have been averted.
At this rate we will never get back into the EU. :roll:
Nictrix
Post by Nictrix » Sun Feb 18, 2024 6:10 pm
flybobbie wrote: Sun Feb 18, 2024 5:45 pm
1 loaded battery
:thumbsup:
ok thanks
Wow....
It pretty much was suggested in the 6th and 8th post on the first page
robertlancaster1094
Post by robertlancaster1094 » Sun Feb 18, 2024 7:04 pm
1 loaded battery
:thumbsup:
ok thanks
Wow....
we dont wanna get back into the EU look at the state of it
robertlancaster1094
Post by robertlancaster1094 » Sun Feb 18, 2024 7:05 pm
Nictrix wrote: Sun Feb 18, 2024 6:10 pm
ok thanks
Wow....
no need to bicker about it its a good thing he finally gave some good advice without being rude
RobbiZ4
Post by RobbiZ4 » Sun Feb 18, 2024 8:54 pm
flybobbie wrote: Sun Feb 18, 2024 5:45 pm Wow....
I remember that I did it already pages ago. :rofl:
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
RobbiZ4
