This Pin 12 trick to open the boot
Ok noted, thanks.
So I may have all hoses correct and second unit has failed? Is there a foolproof way of tracking hoses back or ruling out one by one?
- RobbiZ4
That depends....
The ones from the roof shell are very difficult to track without cutting each zip tie from top to the bottom.
But those on the main cylinders as well as on the couplings easily can be checked visually.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- RobbiZ4
Unfortunately, this cannot be ruled out. Only a test with a pump that is confirmed to be working can provide certainty.
- RobbiZ4
In my Hydraulic-TestBox...
... I've marked all the hydraulic hoses with special zip ties with marker fields. That could be an option for you as well:
OnlineChippie
Is it possible to disconnect the hoses and blow down each pipe in turn to see which is which?
Wow what a setup Robbi.
I bought these plastic clip on numbers that work well, can slide them out of the way to get access.
Still, hasn't stopped me possibly messing up
Interesting idea Chippie, not sure how that would work. I'll have a think over the week and try something else next weekend.
- 9.jpg (96.12 KiB) Viewed 927 times
- RobbiZ4
That could be tricky, as each hose has a diameter of only 2 mm. At first you have to blast out the oil over 3,30m(!) I'm not sure if that works without any adapter for the air gun.
- RobbiZ4
Well, if you've mixedup two hoses from one side of the roof shell, it should turn immediately instead of trying to move forward or backward. That should be easy to diagnose visually.
Update, I had hydraulic lines 11 and 21 the wrong way around. Still not there are the rear shell is moving like a crab, suspect something bent whilst I've been trying to sort this, but a a problem for another day.
Can get windows up finally!
How do I get the boot lid out of maintenance mode?
- RobbiZ4
What do you mean by this: the roof shell is moving very slowly or it gets caught somewhere?
Just pull the BMW emblem when the roof is fully closed or fully opened.
So it does! Thank you Sir
I'll make a video of the movement when I get a moment.
Ok, my crab like rear shell. Cant see anything obvious but I'm sure something must be out of shape.
https://youtu.be/78elbybZWPU
https://youtu.be/rRf77aH86pQ
- B21
Oh dear not good..quite a thump when the shells go into the boot too..Stash36 wrote: ↑Sat Dec 16, 2023 5:44 pm Ok, my crab like rear shell. Cant see anything obvious but I'm sure something must be out of shape.
- RobbiZ4
Obviously a problem with one of the hydraulic rams in the rear roof shell or, a problem with the hydraulic pump!
Can't be justified in any way!
Only tests with replacement parts can identify the real issue. Keep in mind, that hydraulic rams have to be replaced pairwise. If not, the new one will move with a different speed as the old one on the other side and you will run into the exact same problem!!
Thanks Robbi.
Movement was exactly the same with both complete motor units, so I think the motor/pump is good. (Have returned one now for refund).
How certain are you about the RAM and something not being bent? When only one side was lifting the rear shell did twist quite a bit.
The steel looks damn strong and unlikely to bend though, I would think.
I know that's an unfair question but really value your opinion.
And if I go for new RAMs, is it these part numbers... 54377223337 and ..3338?
How hard is the job, I've searched this forum and cant find it being done, I saw one thread where I think you advise its a four hour job?
