Failed indicator
Failed indicator
Hi, My Z4 seems to follow the path many seem to tread. First I had my issue with the tyres, which turned out to be simple to fix. Throw away the run flats.
After that I enjoyed three months hassle free motoring. But then over the weekend….
Indicate left and the flasher goes into overdrive and the lamp warning light lights up. Next turn perfect, and since randomly fault, no fault.
I see from others posting that this isn’t an uncommon fault and new replacements were non-existent. They still are in all the obvious pleases. Does anyone know where I can obtain one? Need a nsr unit for a 2012 2.0iDrive.
Ian
Ian
Failed indicator
Where have you already looked? It'll help us norrow down places you haven't already searched.
Failed indicator
Hi, I checked euro parts and may be 5 others from a Google search. I’ve a couple of quotes from online breakers but figure that’s a big gamble over the comfort of a new one out of the box.
Onlineobewan
Failed indicator
I had exactly the same fault 2 - 3 months ago. I could leave the indicator on and it would alternate between working/not working.
When not working, 3 LED's in the centre of the strip were not illuminating
I took the light cluster out and dried it with a hairdryer for a few minutes
Whilst tipping it around I think about a teaspoon of water came out.
Finally I filled joints between the lens and back plate with a silicone adhesive (specifically for this type of job) from a local motorist shop
https://www.ebay.co.uk/itm/185822976042 ... 3155f719cc
About a month has passed now and so far so good, fingers crossed maybe I caught it just in time
Hope that's not jinxed it
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
Failed indicator
Silicone will eventually pull away as doesn't stick to the plastic well. Tried that several years ago.
Best i did was Evo stick glue.
No problem now 5 years all dry.
Failed indicator
Thanks for the advice. I think I’ll give a repair a try. The symptoms are so similar it has to be worth a go.
I will let you know how I get on.
Best regards
Ian
Best regards
Ian
Onlineobewan
Failed indicator
I get what you are are saying flybobbie and agree silicone eventually comes away, but the stuff I referenced is an adhesive with silicone in it.
It has set fairly hard so I'm hoping it will stay put
.....anyway, time will tell
Honda CB500F.
Honda CB500F.
Failed indicator
Hi, I had the exact same problem with my car recently (Oct 2023). Nearside rear cluster had four LEDs dropping off intermittently, causing a warning light and indicator relay going into overdrive. Web research here and elsewhere showed a replacement cluster was the only answer. Look as hard as I could, I could find no stock in the UK, not even at breakers or main dealers. I was resigned to having to wait for new stock to arrive goodness knows when and pay goodness knows how much for it.
Two weeks ago I ran a search on eBay to see whether there was anything doing and amongst the usual dubious postings for US spec and parts from Lithuania, a post appeared under the banner Blinkin Marvellous, advertising reconditioning services for Z4 E89 rear light clusters. Cautiously I made contact, asked the seller a few questions, the replies to which were fast and confident. I got enough confidence myself to wrap my precious light up and post it Royal Mail Special to Clive, the owner of this enterprise, who is located close to Frome in Somerset.
Tons of updates back and forth gave me reassurance we were good and we were. Inside a week, Clive made the repair with new LEDs, a newly fashioned bracket to repair a crack in the casing I knew of, where somebody had obviously had a go at a previous attempt, he returned it, again by Royal Mail Special and I have it back on the car, working exactly as it should be. I won't tell you the price I paid for this service, I think Clive will deal with that on a case by case basis, but I paid less than I had been quoted for a new non-existent replacement!
If you want to look into this yourself then the best way to contact Clive is to search eBay for item ref 296058767160. Only the initial contact is through eBay, it's mobiles from there, giving further reassurance.
I am very pleased with the service and so based on my experience I would recommend Clive to any of you suffering the same annoyance with your rear lights.
Best regards
IanzZ4 - Chelmsford
ps Clive is a Z4 owner so he may even amongst us
Best regards
IanzZ4 - Chelmsford
OnlineB21
Failed indicator
Good write up / recommendation
- RobbiZ4
Failed indicator
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
