Leaky valvetronic gasket again
ajguk
Post by ajguk » Fri Jul 07, 2023 2:26 pm
:headbang:
Hi all - in February I noticed a leak from my valvetronic motor gasket. I swapped it out for a new unit but it's now doing it again, so this time I'm going to use some gasket sealant to help it along as per this post: https://www.e90post.com/forums/showthre ... 946&page=2 although maybe not quite as much as the last guy used...
I can't seem to find advice on this anywhere, but should I apply the sealant and let it dry for an hour or two before seating the gasket? Or put it on wet perhaps and only torque it after a couple of hours curing? In both cases I'll wait 24 hours before starting the engine to give it a good chance.
I mentioned this gasket change to my mechanic and he asked me if I'd electronically reset the motor - is this necessary? Again advice around this seems to be patchy at best.
2009 sDrive30i, deep sea blue, ivory
flybobbie
Post by flybobbie » Sat Jul 08, 2023 8:04 am
I replaced, never used sealant, but found the original wasn't leaking anyway.
New one doesn't leak. But is a poor design.
Might be cam cover gasket.
I used a obd to recycle the motor. Not sure if it sets itself automatically.
Got me thinking i will recheck my cars today.
RobbiZ4
Post by RobbiZ4 » Sat Jul 08, 2023 10:20 am
ajguk wrote: Fri Jul 07, 2023 2:26 pm :headbang:
Just replace it by another new one bought directly from your local BMW dealer, not online.
I've never heard about a 2nd leak after replacing it with a new one, so I would avoid any sealant.
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
ajguk
Post by ajguk » Sat Jul 08, 2023 11:09 am
Thanks, I'll source an OEM. The last one was an Elring I think from Autodoc.
Also hoping this is the source of my suspected vacuum leak, but we'll see I suppose. Really don't think the cam cover is leaking, there is a very distinct leak from the valvetronic gasket. Maybe I'm unlucky though and it's coming from both!
ajguk
Post by ajguk » Sat Jul 08, 2023 11:30 am
Think I must have just spoken to the cleaner.....he 'thinks' the parts dept is closed today. Very helpful. Guess I'll call back Monday....anyone know the OEM part number for the valvetronic gasket in case I need it?
RobbiZ4
Post by RobbiZ4 » Sat Jul 08, 2023 12:39 pm
:ant:
ajguk
Post by ajguk » Sat Jul 08, 2023 2:58 pm
RobbiZ4 wrote: Sat Jul 08, 2023 12:39 pm 30i 2009
https://www.realoem.com/bmw/enUS/showpa ... Id=11_3736
Thanks! Was on that site earlier but obviously the wrong bit.....
ajguk
Post by ajguk » Mon Jul 17, 2023 4:35 pm
RobbiZ4 wrote: Sat Jul 08, 2023 10:20 am Just replace it by another new one bought directly from your local BMW dealer, not online.
Thanks Robbi - just closing this to say I got the new gasket on Saturday, fitted yesterday. So far no oil leaks and it's cured my vacuum leak, so she now starts on the button and no fluctuation in revs. Chuffed!
RobbiZ4
Post by RobbiZ4 » Mon Jul 17, 2023 7:29 pm
Top! :thumbsup: :thumbsup: :thumbsup:
:ant:
