⌛Y3 Roof Diagnostic System (for all BMW convertible & roadster)
- RobbiZ4
Thanks for confirming.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
viewtopic.php?f=23&t=129048
Y3 Roof diagnostic system
Blame Brexit
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- enuff_zed
Just Robbi's inventive way of bumping his thread
What would the this run?
- enuff_zed
It doesn't 'run' anything per se, it's a fiendishly clever box of tricks, developed by Robbi (and his minions ) to diagnose any issue with the roof on the E89 by monitoring the sequences of every switch, relay etc.
Knowing the Germans' propensity for engineering perfection I suspect it will also make you a coffee while you wait.
- RobbiZ4
... and finally it's able to clean up the dishes.
- Marcoose
Robbi, echoing others, this is brilliant work indeed. Wunderbar!
I’ve been reading your advices here and elsewhere. You say all roofs eventually fail. Would you advise to preemptively replace all parts that normally fail? How long would them last? Or wait until the failures pop up?
You’ve also offered to travel. (California is beautiful this time of the year.) It’d be great to understand how much that would cost.
Thanks.
Marc.
Thanks.
Marc.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
- RobbiZ4
This thread is regarding the Y3 Diagnostic System and should be kept clean.
- RobbiZ4
Interesting story regarding the usage of wire "harness" or "loom"
https://www.interconnect-wiring.com/blo ... led-looms/
"The term “loom” was commonly used in the aerospace and automotive industry half a century ago. A wiring loom, also known as a harness, wire harness, cable assembly, wiring assembly or wiring harness, is an assembly of wires which transmit signals or electrical power. The wire looms are bound together by braiding, straps, cable ties, cable lacing, sleeves, electrical tape, conduit, a weave of extruded string, or a combination thereof. So, the word wiring harness and wire loom are interchangeable..."
- RobbiZ4
You always have to consider that a sensor can not only fail completely, but can also change its switching state with a delay. The CTM always checks the timing as well.
In the following chart, you'll see an unexpected delay of about 1-2 seconds. Time to change both microswitches.
- RobbiZ4
Another interesting result of my Y3 Roof Diagnostic System is the following:
The CTM sends a short current pulse to all the relays and solenoids before starting a roof operation.
I have my roof stuck in the closed condition.
Last winter I discovered a flooded battery well which I dried out. The sponge was sodden. I removed the pump motor which was full of black water and cleaned and dried it. I topped up the fluid reservoir and luckily this seemed to cure the problem after a few cycles to bleed the hydraulics.
This spring I checked for water and the sponge cradle was damp, blut the motor was ok. The roof opened ok but now I can't close it. You just get the dong and the red roof symbol on the dash. I have removed and checked the salmon relays which seem to work ok. I noticed they are different pin connections from standard relays so you have to buy the BMW item
Is there anything else I can check? It's a bit difficult to check anything with the roof stuck in the boot.
- na51hog
Can you read the roof fault code(s) from the OBDII port either using something like the Ancel BM700 tool or an app like Protools or Carly with the appropriate OBDII Bluetooth adapter?
When the fun stops, you know what to do...
Hello,
I am desperate to solve my. Z4 top problems without spending 5,000 or more us. Is your y3 diagnostic tool available in the us?
- Smartbear
Have you looked at the guides on here? They will give you a good idea what’s involved - use the search function.
e85 3.0si sold
