Rotate the pdc graphi
Hi
Has anyone managed to rotate the car image for the PDC viewer on the e89.
Say rotate 90 degrees so the front of the car in the image is facing the bonnet as opposed to the passenger door.
2015 E89 28i Msport Auto - Mineral Grey metallic...
- enzed4
Looks like this is an option in Carly (F series display instead of E series display if I read it correctly). Haven't tried it myself as I didn't think a portrait orientation would look good on a landscape display, but I could be totally wrong. Might have to give it a try....
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- tintoverano
worked for me w/ Carly
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Hi tintoverano
can you post a Pic of what it looks like.
- RobbiZ4
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
that looks good
add to the list...
add to the list...
- enzed4
Ah, so that's how they've overcome squeezing a portrait image onto a landscape screen. Cut the car into front and rear halves and show front or rear (with a small side graphic showing both) depending on which direction you're heading.
Gone: 2010 35i DCT
- RustyZ4
Why ???
Z4 E85 3.0, gone but now with son
- enuff_zed
Cos people have been overwhelmed by technology and forgotten how to park using their mirrors??
You forget that the PDC viewer can be used forwards, too. I use it that way every day, because I park under the house in a space between a wall and a brick pillar covered in ivy that's only a few inches wider than the car. Reversing out is easy - I use the mirrors - but driving the long-bonneted E89 in is safer with some help.
Vidi, vici, veni
- z4pilot
Useful for people who would need to rotate a paper map to point in the direction they're travelling
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
- enuff_zed
I have the same issue with my garage. But no PDC!!!!Busterboo wrote: ↑Sat Dec 07, 2019 12:52 pmYou forget that the PDC viewer can be used forwards, too. I use it that way every day, because I park under the house in a space between a wall and a brick pillar covered in ivy that's only a few inches wider than the car. Reversing out is easy - I use the mirrors - but driving the long-bonneted E89 in is safer with some help.
So, the first time, I drove in to what I thought was right, stopped, got out, checked the gap and pushed the car forward to the right spot.
Then I got back in, made a visual note of where I was in relation to wall bricks etc.
Been fine since then. Simples!
- enzed4
Gone: 2010 35i DCT
I assume you never park anywhere else that has a wall?enuff_zed wrote: ↑Sat Dec 07, 2019 8:34 pmI have the same issue with my garage. But no PDC!!!!Busterboo wrote: ↑Sat Dec 07, 2019 12:52 pmYou forget that the PDC viewer can be used forwards, too. I use it that way every day, because I park under the house in a space between a wall and a brick pillar covered in ivy that's only a few inches wider than the car. Reversing out is easy - I use the mirrors - but driving the long-bonneted E89 in is safer with some help.
