SPAM: Individual water problem, please help
- B21
⌛E89: Retractable Hardtop (roof) Maintenance (and additional) tasks
Tried to order it..only ships to Euro-land…
A very modified Atacama Yellow 35is
- RobbiZ4
Well, that is the BREXIT result.
Have it shipped to me and we will meet next spring/summer in Bavaria.
There is a French Z group planning a weekend mid of may here in Munich with about 30 Z's:
https://www-zroadster-com.translate.goo ... r_pto=wapp
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- B21
That sounds very cost effective!RobbiZ4 wrote: ↑Fri Nov 24, 2023 10:23 amWell, that is the BREXIT result.
There is a French Z group planning a weekend mid of may here in Munich with about 40 Z's:
- RobbiZ4
Update on my first post:
New section "Roof Faults on E89" added with some pictures of the typical problems and possible remediation options.
My turn for hall sensor A696 to go west….RobbiZ4 wrote: ↑Mon Nov 27, 2023 9:58 am Update on my first post:
Just a big thanks Robbi for posting this thread, saved time googling etc, on its location.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Is it worth repairing this small tear in the boot seal? I've got a neoprene wetsuit repair kit so could use the black silicone "glue" from this. It's not letting in water.
- Screenshot_2024-03-20-12-54-31-461_com.miui.gallery.jpg (82.31 KiB) Viewed 538 times
- Screenshot_2024-03-20-12-54-16-844_com.miui.gallery.jpg (53.11 KiB) Viewed 538 times
- B21
Needs to be fixed ..it will leak..the seals are prohibitively expensive so a rubber based repair would be good..
Cheers. Will sort it
- RobbiZ4
Guys,
Why do you place and discuss this specific topic in my maintenance thread?
It's definitely the wrong place.
Because it says roof maintenance issues. Why are you so picky?
- RobbiZ4
Your individuell problem has absolutely nothing to do with maintenance.
This thread was built on request to collect general topics in this how-to section. Of course may this collection be hijacked by you, why not? And why not dropping the problem section at all? Not required anymore.
And of course may I drop my former hints to not hijack your water problems, as already done in the past.
Cause I'm German!
Do you have the vichy.vsrsion of the Z4 with 6; reverse gears and 1 forward gear???
I think the misunderstanding came from the Post Title.If it had said "How to fix problems with e89 roof" or similar it would have been obvious that it was a "How to". Maybe you could have a "Do not add to How to posts" in bold at the top of the post.
I found the post through a search for roof problems not from going through the Submenu. So thought that it was a discussion post.
So I apologise for the misunderstanding.
