Hi All,
As per above really.
I bought my first Z4M coupe a couple of weeks ago and last week on the M25 was reduced to 4 cyclinders if not less! and the EML, DSC and Amber Engine Emissions light.
I pulled over and switched her off to then be greeted with an eratic idle. I turned her off again and left it for a couple of minutes. Upon restart the car was fine all bar the Engine Emissions light.
I took the car back to BMW specialist I bought the car from and the code stored related to the Cam Sensors. The code was cleared, car driven and the code did not re-appear as a current fault. Fast forward two days and the probably happend this morning as I started the car to leave for work. It will be going in tonight to have the sensors replace tomorrow.
I wanted to check if anyone else had experienced this? It's an 06 plate with 50k on the clock, which has only every had 2 things replaced under warranty. A hinge on the glove box and rear shocks. Other than that it seems like it's been screwed together properly.
Interestingly both times the problem has occured the morning after I've brimmed the tank. However I think this is unrelated as the first time I was about 40mins into my journey whereas this time was on inital startup.
