(description from Turner Motorsport, where I bought it from)
Genuine BMW
This is the factory BMW control arm upgrade used on the high-performance 330i ZHP Performance Package and offered by BMW as a sport retrofit. These arms are identical dimensions as the regular arms so they are a direct replacement. But they have all metal ball joints instead of plastic or rubber. This means they last a lot longer and are much stronger. We used these in our Grand Am and World Challenge E46 racecars with excellent performance.
Control arms, and their integrated ball joints, are some of the most crucial components on a BMW suspension. The control arms literally control the wheel and suspension as they go through their range of motions. A faulty or worn control arm or ball joint is a very dangerous and potentially life-threatening problem so make sure they are inspected and replaced at regular intervals. For a street-driven car we advise yearly inspection and a full replacement every 3-4 years. For track-driven cars these should be inspected before every event and replaced every two years.
We also recommend replacing the bushings when changing the control arms. The bushings are mounted at the back of the control arm and located the arm to the frame rail on the car. The stock bushings are rubber and will wear out sooner than the control arms themselves. With the control arm off the car now is the perfect time to also replace the bushings.
This item fits the following BMWs:
1999-2006 E46 BMW 323i 323ci 325i 325ci 328i 328ci 330i 330ci
2003-2008 Z4 BMW Z4 2.5i Z4 3.0i Z4 3.0si Z4 M Roadster M Coupe
only asking $250, it is $329.95 plus shipping from Turner. It is brand new still in the box.
Genuine BMW
