govinderubhi
Hi to all
I have just spent the weekend, removing my roof and repairing my Roof Motor (see post Roof Motor UK for any of those looking to buy parts from the UK, Soper (Lincoln) and / or Motormec)). It all went really well, thanks to Shipkillers in depth and great notes (www.shipkiller.com)
!! It has been said a lot before but thanks for those.
However I have a few issues. The reason I decided to do the repair, is that the roof started to play up. When the open button was pressed, the motor ran, roof unlocked but you could hear it whining and not moving. Eventually, after about 30-40 seconds the roof decides to move, and goes all the way down, with a stop start motion. The same occurs for the up motion.
I thought the motor was on its way out and suspected a loss in Hydraulic Fluid within the system. After removing the motor from the housing, my suspicions were correct, it was soaked in Hydraulic fluid, rather than water as with most.
When I loosened the banjo bolts on the original motor, fluid just spurted out due to a massive pressure build up, which I kind of suspected. I attached the new motor and put it all back together. Operating the roof again, it makes exactly the same whining noise as before and length of time to open. The motor is definitely working and I thought the new motor would have enough 'new' fluid within it to refill the system on the roof so it would work properly.
Do I have to take the roof off again and fill top up the motor with fluid? Can I move the top manually up and down and few times to fill the system with fluid? Anything to do with the Bowden Cable? Any other ideas?
If anyone can help (really hoping Shipkiller reads this) would be really appreciated
I thought, as an added help, that if anyone is looking to repair their roof motor, I have done it very recently so am more than happy to help if Shipkillers detailed notes do not assist.
Gov
Gov
