Hi all, seeking advice on tyres and in particular running front and rear tyres of the same size.
This is not just for winter / bad weather as I would run this set up regardless of weather conditions.
I have previously received advice from a much respected forum member (on wheels and tyres) that a
245/40/18 set up would be a good neutral/ starting point for all round use and I like the idea of the increase in side wall thickness this size gives.
I'm running standard 108s without spacers on stock suspension ( at least I think it's stock)
Has any member tried this size set up and if so what were the results.
Cheers in advance.
Rgds sd
Cheers in advance.
Rgds sd
