mmakay said:
The HACK said:
I have to question the "wisdom" of using swaybars to cure understeer/oversteer problems on a car as a first step, when there are a ton of simple, free changes that would go a lot more to cure which end will lose grip first.
Nearly every purpose-built race chassis has driver adjustable swaybars. Why? So the over/under-steer of a car can be tweeked during the course of a race.
I agree that other factors should be considered when tuning your suspension, but to dismiss swaybars as one of the tuning tools shows a lack of understanding of vehicle dynamics.
These aren't purposefully built racecars. And no purpose-built race chassis, not even F1 cars, have on-the-fly adjustable sways. Even the PTG E46 M3 race car does not have driver adjustable sways. They have levers in the engine bay that allows sway-bar adjustment from up-top that slides the bracket in and out of the bar to tune for stiffness, but I have never seen any series or any race-cars with in-car adjustable sway-bars. This is a first for me. :?
When I work with club racing crews, they'll use the swaybar adjustment as the last adjustment to make in the car-setup adjustments. First thing they'll do, is tire pressure, then alignment/camber, then damper rate, then when all the other adjustment have yielded their optimum results, they'll adjust the sway-bar for that last tenth of available grip since all the other factors yield much more impact on the result.
And please read my post more carefully. What you want to do in terms of suspension tuning, is you want to ADD GRIP to the ends that are slipping first to cure your under-steer or over-steer problems. Hence tire pressure/size, suspension geometry, spring rate, damper rates all are easier to adjust to ADD grip first. Sway-bar stiffness may actually takes away overall grip (that's why when you stiffen up the front bars, the car will end up under-steering, or you stiffen up the rear bars the car will over-steer) if suspension geometry and spring rate isn't tuned properly to the sway-bars. Therefore, you should always maximize the grip with tires, camber/toe, springs, dampers, then adjust the sway-bars accordingly.
Makes no sense to me to add sway-bars first when a simple change in pressure will likely cure your under-steer issues AND give you more overall grip. The only time it makes sense to add sway-bars first is if you intend to keep the ride as soft and as stock as possible. Even then, adjusting tire pressure or using wider tires up front is more effective.
EDIT: Spoke too soon. I guess Porsche GT3 cup cars do have in-car adjustable sways. Certain series do allow cockpit adjustable sways. My bad.
