85genius said:How about going for an aftermarket one, if you spend around £100 you should easily find something that sounds better than the standard one, and if you go for this kit http://www.ebay.co.uk/itm/BMW-Z4-E89-2009-Car-Stereo-Single-Din-Fascia-Panel-Steering-Wheel-Kit-CTKBM33-/272044408176?hash=item3f571c3d70:g:ARwAAOSwsFpWRQiU you can keep your steering wheel controlls
metal licker said:Just tried that parts number on realoem and its saying it don't exist :? - http://www.realoem.com/bmw/enUS/select
Give it a go using your car details![]()
Think it means it is the alternative to what you've got but your right very confusingGizmo-R said:metal licker said:Just tried that parts number on realoem and its saying it don't exist :? - http://www.realoem.com/bmw/enUS/select
Found it right here: http://www.realoem.com/bmw/enUS/part?id=LM32-EUR-09-2009-E89-BMW-Z4_23i&mg=65&sg=05&diagId=65_1474&q=65129350500
Little bit confusing to as what it means? Does it suggest that I can use an alternative?
Gizmo-R said:85genius said:How about going for an aftermarket one, if you spend around £100 you should easily find something that sounds better than the standard one, and if you go for this kit http://www.ebay.co.uk/itm/BMW-Z4-E89-2009-Car-Stereo-Single-Din-Fascia-Panel-Steering-Wheel-Kit-CTKBM33-/272044408176?hash=item3f571c3d70:g:ARwAAOSwsFpWRQiU you can keep your steering wheel controlls
I'm pretty sure mine is an amplified system therefore this would not work but good shout!![]()
