F1ADAM said:
CJ,
Wouldn't other performance mods have the same side-effects? Namely, a mismatch to the OEM settings?
Also, is there a reason why the 2.5 and the M use the 3.64 and the 3.0 has the 3.07 ratio, as suggested by bimster?
All the E85 & E86 Z4 transmissions have essentially the same gear ratios. The only significant exceptions are the "si" automatics. Here is a link to the most comprehensive listing I've found:
http://www.bokchoys.com/differential/GearRatios.htm
The automatic transmissions use a higher ratio differential gear set (typically 3.46) because they lose torque through their torque converter and transmission. The 2.5i automatic uses a 3.64 ratio differential because it would feel a bit underpowered with a 3.46.
The Z4M also uses a 3.62 ratio to give it faster acceleration, but also to enable it to get to higher rpms faster. If you look at it's torque and power curves on a dyno chart you'll see that it only has about a +20 ft-lb wheel torque advantage over the M54 engine found in the Z4 3.0i through about 4,000rpm. With the 3.62 ratio this is increased to a 65 ft-lb advantage, which registers nicely on the customer's butt-dyno and helps justify paying the higher price.
I've gone to a 3.64 ratio in my Z4 3.0i 6 spd. manual (5 years ago) and 3.46 (+ Limited slip) in my 530i 6spd. manual (this year) and they both benefited enormously from these changes. I use both as daily drivers at different times of the year. There is no adverse affect on OEM tuning or system function. In fact the OEM tuning seems to adapt quite well.
There is also no increase in maintenance cost. Engine speed at cruising speed is unchanged except in high speed driving, although the selected transmission gear may be different.
Perhaps this is why fuel economy does not change except that you can expect to lose about 2mpg or so during sustained high speed driving. To be fair, of course, there is the constant temptation to drive more aggressively just because you can, which may also affect fuel economy.
What’s also great about this improvement is that it comes without the weight penalty or appreciable loss of fuel economy associated with adding a couple cylinders to the engine or with building the engine to run at 8,000 rpm, without the maintenance issues associated with a high pressure direct injection fuel pump…or need I even mention NOx injection ...the crystal meth. of the automotive scene?
BMWs typically come with differential ratios that permit high top speeds and high speed fuel economy at the expense of maximum acceleration and lower speed performance. That’s probably important to anyone using the Autobahns in Germany, but most of us who value our driving privileges and continuing car insurance coverage don’t care much about performance at those speeds. What we do care about is the performance available 0-85 mph to accelerate from a stop, through a curve, when passing or merging into traffic, when climbing a hill, and so forth. The differential swap is ideal for improving performance in these daily driving situations as well as at sports car track events. Subjectively, it absolutely feels like the car was intended to drive like this. It most emphatically does not feel like it's some kind of specialised off-road racer being taken on the street...although it certainly could feel that way if supplied with a much higher ratio custom gear set than what we have been discussing.
If a diff. swap is this great, you ask, why don’t more people do it? Well, for one thing, it’s not commercially promoted. Why should someone selling proprietary engine performance modifications like engine tuning for higher octane fuel, exhaust systems, or cold air intakes that deliver 1-4% improvements at selected engine speeds promote non-proprietary alternatives giving 12%, or 18%, or more, real torque improvements at all engine speeds? Likewise, why should automakers promote this option when customers will pay several times as much for more powerful engines? For example, my 530i with a 3.46 ratio differential will accelerate as quickly as a stock 535Xi because the somewhat higher wheel torque on the 535Xi is accompanied by much higher weight.
