Hey I’m new to the forum searching for some advice. I’ve got an 04 Z4 2.5i. Have been struggling with a long crank before start. Have changed 3 different fuel pumps and a dealer ordered filter. Problem I consistently run into is when priming car shoots up to operating pressures and seemingly looses it in the same moment. I’ve pulled the injection rail and none of the injectors are leaking. As you crank the engine fuel pressure builds and will eventually start seems to run fine after that. Looking for any advice someone could give.
