z4 logo placement on hatch lid
BTZ461
 Christchurch New Zealand
After looking at the variety of positions for this, anyone got a template to show the correct position?
On our car the 4 is slightly lower than the Z, it looks a little "off piste" and it seems to be on quite a few images of other cars too.
However a lot are level, which TBH I prefer.
Anybody else noticed this?
Stick on top edge of adhesive tape (1) parallel to bottom edge of rear lid at distance (A).
Mark measurement (B) on top edge of adhesive tape (1).
Remove liner (protective strip for adhesive surface).
Position corner of number ā€4ā€ at measurement (C).
Position letter ā€Zā€ with marked tip up against adhesive tape (1) and press down firmly.
Dimensions E85:
A = 72 mm
B = 195 mm
C= 74 mm
Dimensions E86:
A = 67 mm
B = 192 mm
C= 69 mm
Would be easier with just one badge for sure. Aesthetically correct, no. This coupe is my winter resto project, and I'm enjoying the challenge, and the car, although sometimes things can get a bit out of hand, and this is a good example!
Thank you TomK, exactly the helpful advice needed.
