Good question! The synchro cannot work unless the input shaft is spinning. When all the bits are stationary, it's hit or miss that the dog teeth are aligned enough to engage. Cold thick oil makes it even less likely a slight misalignment can be corrected unless the input shaft is spinning. For the shaft to still be spinning, you must have only very recently clutched. If you've been on the clutch for a while, the shaft will have spun down and stopped.MrPT said:Do you do a proper de-clutch when you stop or just stay on the clutch until it's time to pull away?
bcworkz said:Good question! The synchro cannot work unless the input shaft is spinning. When all the bits are stationary, it's hit or miss that the dog teeth are aligned enough to engage. Cold thick oil makes it even less likely a slight misalignment can be corrected unless the input shaft is spinning. For the shaft to still be spinning, you must have only very recently clutched. If you've been on the clutch for a while, the shaft will have spun down and stopped.MrPT said:Do you do a proper de-clutch when you stop or just stay on the clutch until it's time to pull away?
MrPT said:I take it that this is neutral => 1st we're talking about since you mention "standing still"? The change will be stiffer in cold weather due to higher viscosity of the transmission oil. Do you do a proper de-clutch when you stop or just stay on the clutch until it's time to pull away?
Hi yea it's a 05 2.2 with 39,000 miles I don't use it much and have found that if I place into 1st before starting the engine it's ok but still have to put into reverse after to drive of the drive wayAdamski said:Hi lez, can you let us know what model, year etc your zed is?
If it works fine with the engine off but not when it's running, there could be an issue with the clutch not completely disengaging. This seems to contradict my previous bit about spinning input shafts, but it makes a difference if the shaft is free spinning on it's own or it is being driven by the engine.lez said:...have found that if I place into 1st before starting the engine it's ok but still have to put into reverse after to drive of the drive way
