Hi All,
Don't know if this has been posted but recently bought a Z4 (E85) and one headlight was foggy, moisture in side!!!
Anyway quick fix:
1. Turn wheels on full lock to the side you need to get access too
2. remove access panel in front wheel arch (top one for headlight)
3. pull retaining bar down on rear cover to light
4. remove rear cover
5. run engine and turn all lights on to dry out light, use hair dryer on outside to assist with drying.
6. use a small flat blade screw driver and prise out rubber gaskets on rear cover.
7. clean gasket
8. turn gasket over and refit, the gasket will fit!!!
9. rub silicon grease over rubber gasket and refit once headlight is clean of moisture.
All done.
Anyway quick fix:
7. clean gasket
All done.
