Had my 3.0i Z4 6 years and finally getting it on track with Bedford Autodrome trackday booked next week.
Cars standard apart from B12 suspension, strut brace, M3 CSL alignment, 3.0SI front brakes, drilled discs, yellowstuff pads, braided brake lines and ATE200 fluid. Goodyear Eagle F1 tyres
I've tracked previous cars but they've all been less powerful and none FR (civic vti, MR2 mk2 and mk3).
Looking forward to it but bit apprehensive and was wondering if anyone has any advice regarding both the car and track.
It's going to be about 24 degrees so what tyre pressures would be good to start with, 30/33? On the road the Goodyears feel like they've got pretty soft squirmy sidewalls, particularly at the back, which don't inspire confidence so not sure how low I should go.
Is it best to turn off the traction/stability control to avoid it overheating rear brakes?
Would appreciate any advice re Bedford, such as corner/gear selection and which corners are just a lift etc.
Cheers for any advice.
Jeremy
Jeremy
). So its either worth taking a spare set of pads, going easy on the brakes or upgrading the pads before you go to DS3000, bluestuffs or better.
