Hi guys hope someone knows these gearboxes on here. Got my car out and can't get gears properly. Yellow cog light is on the dash and have to over ride it to get a gear and then it has issues when I put it in reverse as it wants to go forward from cold. If I let it warm up I can get it to select the correct gear but will only go to third which to me appears to be like a safe mode? Got underneath it yesterday after charging it up and when you turn the ignition on you can hear the pump straight away as usual but then when I start it up in neutral it makes a clunking noise around the gearbox almost as if it's trying to select a gear?? Anyone have any ideas???
