FOR SALE Z4 E85/E86/MINI R56/R57 PADDLE SHIFTER MOD!
For Sale
IAmOrion
Cambridge, UK
PCBs finally designed, fabricated and tested.
*Bare* PCB pictures attached - they will obviously be complete when purchasing so nothing to build/make/solder
A simple, easy, direct swap PCB mod which allows you to CHOOSE/SET what each paddle direction does on each side!
For example:
  • LEFT Paddle (Both Push and Pull) DOWN a gear
  • RIGHT Paddle (Both Push and Pull) UP a gear
  • LEFT Paddle PULL = DOWN a Gear, PUSH = DO NOTHING
  • RIGHT Paddle PULL = UP a gear, PUSH = DO NOTHING
Each paddle can be customised independently and the push or pull can be customised too to suit your preference. The above examples being the most common paddle function behaviour but each side and each direction on each side, can be set however you desire.
There's 3 Version -
  • AUTO -> 3 Pins connecting to steering wheel loom in a 6 pin plug (with remaining pin blocks empty). This can be configured using solder bridge pads OR switches
  • SMG -> 2 Pins connecting to steering wheel loom, 2 pin plug. Slide Switch version
  • SMG -> 2 Pins connecting to steering wheel loom, 2 pin plug, Solder Bridge Version
In most cases, pre-soldered solder bridge would be the "go to" one. The solder bridge could also be changed by yourself at a later date if comfortable with a soldering iron and small SMD pads. I will pre-solder them to as per your choice so that rhey're ready to fit upon arrival
The switch versions are for those who may which to adjust at a later date but are not comfortable with soldering.
It's quite possible other model BMWs also use these same paddle pcbs and so this mod may work on other models also
It is a seemingly simple mod, but it has taken some time and investment to R&D these.
I will put together a quick guide on how to change the PCB hopefully over the weekend and post into the relevant forum section. (I will update this post with that link when done)
£40 Delivered in the UK, Happy to post to USA etc as I've done with previous mods, but postage will have to be quoted and agreed upon on a per person basis. £50 Delivered to USA, £50 Delivered to Australia.
Payment via PayPal Goods & Services to maintain both buyer and seller protection.
Any question please do reach out.
Hi, firstly, thanks for taking the time to r&d this mod.
I would like to order a pair of these pcb’s for a standard auto. Shift down on left paddle push and pull and shift up right paddle push and pull. Can you please pm me your details so I can make the payment.
Many Thanks
Andy 👍
Many Thanks
Andy 👍
Message sent 👍
