Hi,
I am looking to build a z4 racing car/ tack car, Before i really get into the project i just wanted to check out a few things to ensure that things work as i assume they do.
The car would be based around the Z4 e85/6 bodyshell (once i have found a usable coupe bodyshell that is)
The questions
will an e46 m4 rear axle drop in?
Is the ABS body loom fundamentally separate from the other body electrics?
I am assuming that the engine bay is dimensionally the same as a Z4m
Are their any body shell differences between a "cooking" Z4 and a Z4M
Does the rear floor require additional bracing to cope with track use.
Does the dash cluster take engine data via can bus? or is it the usual tacho line etc
Many thanks in advance!
cheers
Iain
The questions
cheers
Iain
watching with interest
