Hi there! I’ve a problem with my beloved Z4 roof. I’ve scrolled through previous posts but not sure I’ve seen a similar issue or solution so hope you can help!
Press button to open, windows go all the way down, the green light is illuminated on close roof button, then nothing. The close roof button won’t close windows so need to use windows button to close.
The low battery warning comes on occasionally so we charged it but didn’t help.
After googling, we then found the motor and pump was sitting in its very soggy foam cushion, took it out, dried everything but still nothing. Bought a replacement motor from Roofmotors, fitted it easy enough, but still nadda, although there is a buzz from the boot when trying to open. Should I have bought the more expensive motor and pump unit? The original pump looks ok with no corrosion. We also replaced the salmon relays.
Any ideas?
Any ideas?
