Yellow
TINO
 cambridge
After a steady drive the other day on comes the engine emissons light yellow, car runs ok slight over run on throttle pedal but other wise goes very well indeed,can not fault. looked into the engine bay checked most things only to find the air flow meter rubber hose split, seems a common prob as most have found it Whistle.
New part has arrived and will fit tommrow,will this cure engine light or not,will it still be on???
Can it be reset????
Or will it have knocked out a sensor??
If so which one?? :|
