Hi all,
I need a bit of a heads up as to what might of happened to my lights.............
I recently had a new control module fitted under warranty at my garage approximately 1 month ago if that as it was corroded and failed, since then the headlights have still been quite wet inside so I ordered 2 new headlight backs, I read on a post on here that to remove moisture from the headlight you can remove the back and drive it with the lifts on and this should clear it which I have done before and worked a treat, so this afternoon I did such that,
Unfortunately it started to rain very lightly, I was aware I would have to drive home without the backs on with light wetness on the road but it's only 8 miles from where I work, within half a mile the light failure sign came up on my dashboard, bugger
, the opposite side in which has just been fixed was out (xenon headlight), i then had to stop 2 miles before I got home to buy a train ticket and when I got back into the car and turn the key to sart the car to my despair the the other side had died as well, I had to drive the rest of the journey with just fogs on
I removed the little back plastic wheel arch light access cover to see if water had got in as the back wasn't on but there was hardly any water anywhere, I saw one or two drops
Can anyone help on this matter, I really can't see how the back not being there could kill both light within 15mins of each other, maybe a fuse perhaps? The car is now booked into the garage that fixed it first time, sorry to go with the story but trying to give as much information as possible
Any ideas/help would be more than appreciated.....
