My Xenon lights suddenly stopped doing that initial up/down cycle during start and they are constantly in the maximum low position pointing downwards. During the up/down cycle there is a humming noise but no motion in either of the headlights.
I've searched the forum and found that this usually caused by a faulty/broken trailing arm level sensor.
I removed both front and back sensors, tested them on the bench (with power supply and multimeter) and they both appear to be fine, 0.5V - 4.5V linear output range when moving the arm.
I'm a bit stuck at the moment, has anybody had this issue before or does any of you have any idea what to check next?
Any advice is welcome.
Cheers,
René
Cheers,
René
