ErrErrminator
I seem to be amassing a collection of headlights in my mission to de-tango the front of my Zed, TBH I’m wishing I hadn’t started down this road. Is is getting complicated and expensive!
I wanted to acquire two facelift halogen lights and simply swap them over with my current ones. No cutting/opening up of units or swapping internals, nice and simple. I picked up N/S and O/S units separately. One cheap, one not so. The cheap O/S one has a couple if issues in that one bulb holder is missing and the reflector chrome coating is poor. So I found another O/S light, which arrived today. This was described as a non-xenon unit, but upon inspection I see an extra connector on the bottom of the case, inside the dip beam unit looks different, has a thick black wire unlike the others and the side light wires have been cut. From a quick look on the net this is definitely a xenon unit, minus the ballast and bulb.
My question to those in the know is, can I swap internal bits from the poor halogen unit, into the xenon unit, but keep the xénons better reflector, to make one good O/S headlight?
Hope that all makes sense.
I’m a bit miffed at being mis-sold a xenon, but if I can make it all work out then the situation may not be so bad.
