x2 LHS halogen Headlights for project
tomTVR
Lense is dented/scratched and the back is missing some brackets but ideal for spare parts and practicing a cut 'n' shut project
£10+p&p
Second one is absolutely mint apart from a piece of chrome trim has fallen off and is floating around inside. Very easy to fix (these just pop back on) if you know how to cut open and re-seal a z4 headlight.
Perfect if you're doing a cut 'n' shut project, buy this and sell your current ones on for £120+ instead.
£40 + p&p
Apologies for the bad pictures, they are a bit dusty and they steamed up when i brought them in from the garage.
How big/deep is the dent? providing that its not too noticable, i'll take it. where are you from?
cheers
I won't lie to you, the dent in the first headlight is bad enough that you probably wouldn't want to fit it to your car. It's invisible from most angles but when it catches the light you can see it and it would piss you off!
The second headlight is mint though apart from that chrome piece.
I'm based in York, I've posted headlights in the past and it would cost about £12
Fancy doing a deal for your CS compadre on the decent one Tom?
Is it possible to pop the chrome back on without taking it apart? Or can you not get a finger in there?
