Wtd: near side headlight
RichD
 Leicestershire
Hi all,
I'm after a near side headlight with orange indicator. I'm fed up with mine steaming up'!
If you have a set of xenon then even better!
Rich
maxman said:
Have you tried a new rear cover,they are about £12 from the dealer.This is the usual suspect
+1
Unless you have cracked the headlight?
Thanks for the advice guys, i took the seal out the back cover and made sure it was sitting OK, but still have a lot of condensation. Getting the water seems fairly easy, but i can even see water build up in the projector lense itself.
What do you think? I don't fancy taking the bumper off! However Is that the only way to remove the headlight?
The seals over time seem to firm up ,losing the compression ,resulting in a poor seal.
