Work completed since March :)
Coffee331
Dublin
I was just listing work I have completed on my car since I bought it last March. Turns out I was more productive than I first thought :lol:
I bought the car to both drive and work on, so happy to say have installed / replaced everything on this list apart from the ABS sensor. I know my work is far from as significant as some members on here but my skills are slowly improving :rofl:
Stuff Completed....
Roof module replaced - fixed roof electrics
Tinted rear light yellow bits
Front lip install
Black kidney grills
Tinted side indicators
New wheels
New Tyres
Carly coding - lights, locks, alarm
New air filter
Oil filter replaced
Oil change
Oil sender replaced
New plugs
New door handle and carrier
Aux in fitted
Bluetooth / music streaming fitted
Amp fitted
Stubby fitted
Rear discs & pads replaced
Drop links replaced
Tie rods and boots replaced
Roll bar bushes replaced
Steering wheel re-trim
CDV delete
ICV clean up
Door sound proofing installed
New wipers installed
ABS sensor replaced
New number plates
BMW logos replaced all around car
Gear knob replaced
G-Stop fitted
Center brake light unit replaced
Gaptech remote roof fitted
HID front fogs
Sonar headlights
Still more to do, but that’s all part of it :)
There you go :thumbsup:
Tcochrane92 said:
Good job!
What did you use for Bluetooth music streaming?
Used this....works great
Bluetooth Music Handsfree CD Changer Adapter BMW E39 E83 E53 E85 Business CD
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F222340478848
Coffee331 said:
Tcochrane92 said:
Good job!
"Head units with DSP are not supported" :headbang:
Coffee331 said:
Tcochrane92 said:
Good job!
Interesting...Where did you put the unit? Does it interfere with the existing Bluetooth calls? Car looks sweet BTW.
idej_jedi said:
Coffee331 said:
Tcochrane92 said:
Good job!
I left the unit behind the pop out panel under the heater controls. If I ever want to use the sd or usb I can get at it easily...although I doubt I ever will lol. I only drive the car at weekends, only fitted the unit recently so haven’t used it much but it seems to do exactly as advertised so far.
markalp said:
Steve84N said:
Coffee331 said:
G-Stop fitted
What's this...?
Thats the magical lady button we are suppose to find... oh wait.. "Stop" not "Spot" .. ignore what you just read.
The g spot is all that comes up when you Google it! :rofl:
Edit: Found it, it's a flasher... :o http://www.gstop.co.uk/
Not sure if it works on pre-facelift but I coded flashing brake lights under hard braking on my coupe.
I thought it was something codeable too? Does anyone know? For the pre facelift...
It’s nothing to do with G spots :rofl:
I don’t know if the flashing brake lights can be coded on a pre facelift; I don’t recall seeing anything on Carly but I wasn’t really looking for it either.
I had bought a G Stop for my main car and they emailed me with offering a second unit massively discounted so I thought why not for the Z :)
It’s a good product, works well and simple to fit.
I seem to remember reading in the handbook of my Alpina which is the pre facelift, when braking hard the whole ring of the rear lights light up rather than just the outer arc of the brake light, no mention on flashing the brake lights.
I have never actually seen it happen though because i'm always driving lol
Is it a discount code? Maybe you could share it in a PM? :D
It was April last year that I got the code. They are only £8.99 on Amazon now so pretty cheap even without a promo code :)
GSTOP ® LITE Accelerometer G-Force Monitor Brake Light Flasher - Retrofit EBLD System https://www.amazon.co.uk/dp/B01IW2RBJA/ref=cm_sw_r_cp_tai_6S8xAb9SYXFNH
Any pics of where/how you fitted it? Not so worried about actual wiring, just best placement of the unit and where you found best to cut into the wires. :)
I fitted it to the underside of the boot and tapped in to the wires of the middle brake light. You just cut the factory wires and wire this in to the feed. It’s important that it’s placed flat(ish) for the G sensor to be able to function correctly under heavy braking.
