Word of warning - The MAF shop...
AndyBeech
 Wiltshire
Seeing as my MAF is on about 66k I thought it might be prudent to replace it, just as preventative maintenance. No particular symptoms of a failed one I should add.
I read a few things about The MAF shop, reasonable prices, ship from Germany, seemed legit. So thought I'd give them a shot.
Got my MAF today in the post, about 8 days from ordering so not too bad.
Packaging wasn't great, a few of those styrofoam things in the box but no particular protection. The Bosch box looked intact so wasn't too worried.
First thing I noticed was the security seal was broken on the box, no big deal to be fair, some places do this to add their own 'warranty' tag on the item, which turned out to be the case.
What was more concerning, was upon opening the box, I was greeted by a brown crumpled grease paper type packaging, not a problem again, something to cook my chips on later, bonus.
Assuming the MAF would be nicely wrapped in its own protective packaging being a highly sensitive and delicate electrical item, I was swiftly proved wrong. As I unwrapped the grease paper, the MAF was plonked totally unprotected in the middle. At this point, I had to have a laugh to be honest, almost presuming this to be a joke.
To probably no-ones surprise at all, the MAF was damaged, the wire being obviously bent and the MAF generally looking like a well worn second hand item. Not impressed at all:
http://tapatalk.imageshack.com/v2/15/01/30/f8860ed840d6a8b519af0f0a9f0c26bc.jpg[/IMG
[img]http://tapatalk.imageshack.com/v2/15/01/30/e8c0972e9dc5b96dc24f6ef8a4c80bf8.jpg
I thought I'd whip mine out to compare my 'old' MAF and the supposedly 'new' one. Mines at the front, 'new' one at the back:
So I've emailed for a refund, don't even want a replacement. Hopefully they'll not mess me around.
I'm sure some people have had no problems with these guys, but for me, genuine costs more for a reason, I wouldn't risk going 'cheaper'. Even though it seemed totally legit. Rookie error lesson learnt.
This was a MAF for an 'M' by the way but will apply to others here I presume!
Good point, was 10/2012. Would suggest it's been sat about for some time as well, not ideal again!
Stuartt said:
That's how Bosch parts are packed
Did you try the MAF to see if it worked?
No need to test it, I'm not going to exchange my MAF for one with a bent wire. Brand new should be brand new, not already half broken!
Are you telling me 100% if I brought a new MAF from BMW that's how it would come packaged? Seems crazy for such a delicate part! If they've opened the box to put a sticker on it and it was fine then it's been damaged surely the packaging is inadequate?
I think that's just the temperature sensor wires that's bent. Looks like a diode being used to sense temperature. It won't effect it's operation. The Maf sensor is hidden in the end bit. Obviously not packed well though.
The wire you are talking about is the temp sensor..
When Bosch make the MAF from new, the sensor is an option depending on whether you have a 4 or 5 wire MAF set up on the car.
So it may have been put in at a later date as the selling company only had that style in stock. If that's the only problem I wouldn't worry about it.
I have done the same temp mod on probably 50 MAF's and never had a problem
