PerryGunn said:Although it's possible, you probably don't want to use the same power feed for both dashcam and TomTom as routing the power cables could be a bit of a nightmare
For the dashcam you can pick up a switched 12v feed from the lighting console - this thread shows the process for an E85 but it should be very similar in the E89
For the TomTom, pick up a 12v to 5v converter from somewhere like eBay and connect it to a switched 12v feed from the fusebox using a piggy-back fuse holder.
If you use a converter with a trailing USB socket, like this, you can then use whatever length USB cable is appropriate to route to your TomTom
markplant said:I used this type to power the same type of USB adapter above, for a tablet install
FsXTimmix said:markplant said:I used this type to power the same type of USB adapter above, for a tablet install
Both my tom Tom and Dash cam use the cigar lighter adapter for power. Can this be used with the USB item your talking about?
PerryGunn said:FsXTimmix said:markplant said:I used this type to power the same type of USB adapter above, for a tablet install
The cigar lighter adaptor just converts 12v to 5v - with the USB adaptor you just use a standard el-cheapo USB lead to power the device
If you want to power both appliances at once you can get ones with two USB flying sockets - as I said earlier, you're probably better with two separate adaptors (they're only a couple of quid each) and hide one in the lighting console as this gives a very easy dashcam installationFsXTimmix said:PerryGunn said:FsXTimmix said:Both my tom Tom and Dash cam use the cigar lighter adapter for power. Can this be used with the USB item your talking about?
Oh cool, so if i purchase that adapter, and take power from the fuse box, I can power both the appliances from it? Will they only turn on when the ignition is started?
That's for the E85/6 - the OP's posted this in an E89 section so I'm assuming that's what he has...markplant said:http://www.z4-forum.com/forum/viewtopic.php?f=3&t=38888
There's a guide part way down this thread shows which fuses are always on and switched
I must start paying more attention to headings :roll:PerryGunn said:That's for the E85/6 - the OP's posted this in an E89 section so I'm assuming that's what he hasmarkplant said:http://www.z4-forum.com/forum/viewtopic.php?f=3&t=38888
Happens to me all the timemarkplant said:I must start paying more attention to headings :roll:PerryGunn said:That's for the E85/6 - the OP's posted this in an E89 section so I'm assuming that's what he hasmarkplant said:http://www.z4-forum.com/forum/viewtopic.php?f=3&t=38888
PerryGunn said:Happens to me all the timemarkplant said:I must start paying more attention to headings :roll:PerryGunn said:That's for the E85/6 - the OP's posted this in an E89 section so I'm assuming that's what he has![]()
I was in the process of editing my post to say that the OP may be able to use that thread as a cross reference for the equivalent circuits to look at for a switched live in the E89
If your 06 is a roadster its e85 , coupe of similar shape e86 , the later z4 with folding metal roof is e89FsXTimmix said:PerryGunn said:Happens to me all the timemarkplant said:I must start paying more attention to headings :roll:![]()
Sorry, i'm not quite up to date with how the forum works! I have a BMW Z4 2006, so i'm assuming that's not the E89?
markplant said:If your 06 is a roadster its e85 , coupe of similar shape e86 , the later z4 with folding metal roof is e89FsXTimmix said:Sorry, i'm not quite up to date with how the forum works! I have a BMW Z4 2006, so i'm assuming that's not the E89?
So the above link to the fuse guide is relevant to your car
