wipers?
Buckz
West sussex
Hi guys
what do you recommend wiper wise? I have some bosch now but the passangers side is not sitting flush.. wondering if there's a make that actually makes wipers that fit?
Because of the curve of the windscreen I don't think any wipers really fit nicely, I went an inch down on standard with aero wipers and looks ok. Squeak a bit though
Yeh, the screen really curves away considerably at the edge of the passenger side. Looks like these are the main options, maybe try an alternative to the Bosch and report back if any better. The Michelins look interesting.... https://www.wiperblades.co.uk/bmw-z4-years-2002-to-2009-wiper-blades/
Soft Cover:
Provides maximum flexibility for enhanced responsiveness & protection from clogging with ice, snow and debris.
Independent Suspension Tertiary:
Adjusts to windscreen’s shape/curvature to help maintain complete wiper blade contact.
Smart Flex Secondary:
Holds wiper ends down on windscreen for optimum wipe performance.
Riveted Smart Hinge:
Provides maximum lateral strength to eliminate twisting of the frame during the wipe and to hold a secure, consistent position on the windscreen.
Actively responds to windscreen shape or curvature across the entire wipe pattern
Soft Cover:
I got the Michelin’s recently, they are a great fit and super quiet / smooth
I recently replaced my standard Bosch with standard Bosch, all good. I use any window cleaner to get rid of spots on glass.
Anyone tried any other blades over the winter? I caught mine when drying the car the other day and bent it slightly so it doesn't wipe properly anymore. Thinking of giving these a try...
https://www.wiperblades.co.uk/bmw-z4-years-2002-to-2009/lucas-lwdf21-retrofit-flat-windscreen-and-lucas-lwdf20-retrofit-flat-windscreen-twin-pack-wiper-blades/
...or
https://www.wiperblades.co.uk/bmw-z4-years-2002-to-2009/michelin-stealth-msw12921-hybrid-wiper-blade-and-michelin-stealth-msw12920-hybrid-wiper-blade-twin-pack-wiper-blades/
I bought those Michelin stealth blades from costco a few weeks ago, £6 per blade, bargain.
I went for an inch less on both blades, so they fit the windscreen better. (19'' and 20'')
Other the years i've gone through all sorts of different blades, standard oem style, flatblade bosch aerotwins and now michelin hybrids, and these are the best in terms of noise.
All the others used previously always made a screeching noise as they wiped.
My old Bosch ones where noisy as anything...replaced last week with old skool Bosch ones with spoiler... much better.
Why not go crazy and get the bmw ones, y'know the ones that actually fit?
Paid £10.79 for my last replacement passenger side, £4 I can do without saving.
ETA lols didn't realise people were paying more for aftermarket ones that don't fit and squeak apparently :dizzy:
Double Edit, ok those prices are for a set..... still there's not a whole lot in it.
Mine are currently OEM but they don't follow the curve of the screen that well, particularly at the very edges of the passenger side at rest. They are off the screen by a good 2-3mm. They do wipe OK (or at least they did) though.
Nothing against OEM, just that they will have been made to a price and designed more than 10 years ago to boot. Technology moves on.
Are there any out there that actually fit the screen any better than the BMW ones on that passenger edge? My new one fits pretty well, although I'd agree it's not absolutely perfect. I tried some bosch (aero I think) ones and the gap there was a joke, it looked awful.
What do modern wiper blades do that 10 yr old ones don't out of interest?
Perhaps don't do anything particularly new, just do what they should do better! For example the Michelin ones seem to address the main gripes I have:
  • Independent Suspension Tertiary:
  • Smart Flex Secondary:
  • Riveted Smart Hinge:
  • Actively responds to windscreen shape or curvature across the entire wipe pattern.
Then you have the special coatings like the Graphite on the Lucas Clearvision. They are certainly not all created equally. Anyway, I have the Michelins on order so will be sure to post an unbiased review when I test them out.
updating this, I have had a set of michelins on the car for a while now and they wipe really well and are much quieter than the bosch I had on before.
there's a problem that the passengers side still hangs in the air(too long I guess) and it is pressed too much against the windscreen which results in a "small" tick every time the passengers side wiper moves..
ph001 said:
Were they the Stealth? As Ben G stated, the 19" & 20" might actually be the optimal size.
yup, 20/21 inch as recommended by BMW but I am sure a shorter wiper would work better on the passengers side. Drivers is fine.
Thing is, the oem ones do all of the important bits of that better than the newer 'improved' ones I tried.
Anyway, let us know how you get on with the Michelins, I'm all for using them if they fit properly and are cheaper.
