Hi All,
The wipers have not been parking properly and working intermittently so when I read the thread about the excess grease in the motor I thought I had cracked it
however when I got my motor off and stripped down there was no excess grease inside. I replaced everything and put the wipers back on the splines at the correct parked position. The wipers now worked ok apart from position 1 = intermittent wipe correctly, position 2 which should be constant wipe was still intermittent wipe and position 3 is normal speed wipe not high speed. You still with me
So I bought a replacement relay from the stealers, removed the old blue one and replaced it with a shiney new black one, symptoms did not change :roll:
So do you think it is a faulty stalk or faulty motor?
Thanks for the help,
Tom
Tom
