Hi all
Had an issue the other day with the drivers side wiper stopping, stripped arms off and cover earlier and the ball joint had popped off the arm, I have been able to pop it back on and it's not dropping off (though is a little loose- so guess it needs pinning somehow or it will soon pop off again)
pushed back together
Having read several threads and posts on here I have seen cable ties, drilling and using split pins, and linkage clip kits mentioned,the clip kit can be seen here - its for a puto but off a thread on here so guess it fits!
Any ideas which is best option?? my head says the clip (assuming its a universal fit) pin is hard work,and cable tie is easiest but probably wont last?!
P.s. I cleaned it and pulled all the crap out after I took the pics
